Choke pulloff vacuum?
Ok, so help me out with a noob question..
What port should a quadrajet choke pulloff connect to - ported vacuum or thermal vacuum? Thanks all. |
What carb-#?
1974 and earlier Pontiac Q-jets uses only a primary choke pull-off connected to a full manifold vacuum source on floatbowl passenger side next to fuel inlet. 1975 and later Pontiac Q-jets also uses a primary pull-off and in addition to this a secondary choke pull-off controlled by a thermostatic valve. |
Manifold vacuum, or any source below the throttle plates when the engine is at idle speed. This will apply the choke pull-off at initial engine start-up and unload the choke flap to keep the engine from flooding out.....Cliff
Its a '76 quadrajet. So if I am getting this right I would use the middle port between the pcv and water ports?
Take a look here:
Mine looks different. See the red circle in the attached photo. What port does this get connected to?
Thanks... |
Hooking it to the small vacuum fitting on the vacuum tee in the back will work.
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
Hooking it to the small vacuum fitting on the vacuum tee in the back will open the chokeblade too far with cold engine.
This is the secondary pull-off wich should be connected to the thermostatic valve. It was used for emission purposes but is really not needed so you can omit it if you like a cleaner look. |
Kenth, good advice, we NEVER install them unless it is a full restoration to every detail, they are not needed.....Cliff
