Bilsteins
I'm considering putting Bilsteins on the '67 LeMans. I've heard more positive than negative reviews on them, and their own site says that they work well with factory springs. We'll be replacing the springs as well of course, since they are original and worn out.
I was on their site and found the front shocks no problem. But they don't show rears for a '67 Pontiac A-body. I found this strange. Why wouldn't they have a complimenting shock for the rear. So I do what I always do, which is to input a Chevelle into the search box. Sure enough, there they are for a '67 Chevelle. I wasn't aware that there would be a difference between the Pontiac and Chevy rear ends. Is there a difference that would prevent me from using the rear ones spec'd for a Chevelle, or is this just an oversight on their part? |
Same issue with my 67 Nova. Finally found Fox shocks for the front.
69 Z 302 M21 3.73 http://www.byjanmarie.com/camaro/Z28.html 69 FB 400 http://www.byjanmarie.com/firebird/69.html 69 Camaro 327 4sp. 4.10 http://www.byjanmarie.com/camaro/69camaro.html ( SOLD) 2002 Camaro LE/SLP-(sold) 1967 Nova SS-- 327, M20, 3.73, FRT Disc |
Have you tried calling Bilstein of America? I have not talked to them in a few years, but they used to be quite responsive and could even make custom stuff.
I actually called them and they had no plans to make shocks for the front of a 67 Nova.
Konis work well.
Wow, in shopping around for the KONI's, it appears that they cost more than the Bilsteins.
Koni's are adjustable, Bilsteins are not. That doesn't mean the Konis are necessarily better but may offer increased flexibility if needed. With increased functionality, usually comes increased cost. My car has Koni but I put in a set of Bilsteins in a friend's C3 Vette and they were balanced perfectly for that car. Either shock is going to be a solid choice.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
Too bad the old HO-Racing springs are no longer available. I know Ken Crocie sold the rights to Malibu performance, but they recently gave up on selling them. Those springs with Bilsteins made for a NICE ride and excellent handling on A-bodies. I installed that combo on several.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
Hey 66 sprint..........have bilsteins on my 66 Gto.......front 24-029728 # under that F4-BE3-2972- H 1
Rears are 24-009294 Hope that helps Rich |
I did call Bilstein and asked them about rear shocks for 67 GTO. They had no listing and gave no helpful info.
Gtorich...how did you come up with the part # for the rears? Thanks |
I know they are on summit racing, seems to stop at 68 or so.............otherwise no problems with them on my 66. Rich |
Ok, did a search, had some things screwed up, i had the old # for bilsteins AK 2080, they said the 24-00924 would work, think Bart chimed in my post from April 22 2019, this is when i was looking for a replacement of the AK 2080 rear shocks from bilstein.
Kind of a pita, but got them in ok......Believe the post title was Bilstein AK2080........hope this clears up some of the confusion. Rich |
I bought these Bilsteins for my ‘64 Tempest about 12 years ago. The same ones will fit your ‘67, hopefully they’re still available.
That's all super helpful. I believe that for whatever reason, Bilstein didn't create a listing for a '67 Pontiac A-body and maybe they don't feel like creating one. But they are available so I'll grab them.
66sprint6...Where are you getting them? Part #s? Thanks.
I went directly to Bilstein for the part numbers. Then I just googled to get the best price. As it turns out, I can buy them directly from Bilstein in Canada. In the US, you have to buy from a retailer.
Here’s the current part numbers. https://cart.bilsteinus.com/details?...51489&Pos=Rear https://cart.bilsteinus.com/details?...1489&Pos=Front Hope that helps. I’ve seen them listed on EBay with the old part numbers as well (AK2020, etc). |
Have you ordered them yet? Curious on fitment and ride quality.
Sean 1967 GTO Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI |
I haven’t ordered yet, but I intend to shortly. I’ll definitely post a review after installing them.
Yeah, you can't go wrong with Bilstein or Koni. They're both high quality. Interestingly, I noticed that UMI Performance now supplies Bilstein shocks with their complete suspension packages rather than their own in-house UMI shocks that they used to include until very recently. They don't list the actual part numbers on their website, but I bet they'd provide that info if you contacted them.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
