Old 05-03-2021, 07:48 PM
68WarDog 68WarDog is offline
Default 421 short block
I have the opportunity of purchasing a complete 65 421 standard bore short block for $1k. Is that fair market value?
Old 05-03-2021, 08:00 PM
steve25 steve25 is online now
I would say so, even though you will not use the pistons and rods if they are stock!
Those steel rods in those 421 motors are weaker then the cast rods!
Verner Von Braun warned before his retirement from NASA said that the next world war would be against the ETs!
Old 05-03-2021, 08:15 PM
Definitely fair, probably closer to the lower end price wise.
1956 VW Type II Panelvan 36hp 1200
1957 VW Type I Bug 160hp 1835
1966 VW Type II Single Cab Pickup 57hp 1600
Old 05-03-2021, 08:17 PM
Thanks Steve. Although I would go with an after market rod , wasn't aware that 65 rods are considered weak. Thought that was the 58-60 forging?
Old 05-03-2021, 10:26 PM
Mike Davis's Avatar
Rods used in the 1965 421 is the same as used in all other V-8's from 64-79----
If it is a STD bore and the crank is good that is a good price. Should have a Armasteel Crank. Not as nice as a the earlier 990 forged but a good crank worth about $350-$400 itself.
Worlds fastest All Steel 66 GTO with a 421 and AFB's. (until proven otherwise)
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, Carter 750 AFB's, TH400, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.79@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
67 GTO 2dr Coupe 428, Tri Power, 3.55 Gears
80 Trans Am SE W72 WS6
Old 05-03-2021, 10:55 PM
4dblnkldude's Avatar
$1,000 bucks? I'd set a land speed record for my wallet.
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 05-04-2021, 06:33 AM
Some of the early 1965 421 motors where STILL using the basically steel version of the cast armsteel Rods, I know as I have taken apart not one, but two of the 370 hp rated short blocks and both of them where made as such!
I know, I was left scratching my head also!
I think I still have the block production dates of those two short blocks in my info , I will look.
The 990 Crank was only fordge for usage in the SD motors, and I can guarantee you that none, zip zero ever found there way into a production line 421!
Old 05-04-2021, 07:01 AM
Cardo's Avatar
Cardo Cardo is offline
Where do I pick it up?!! Sounds like a good price to me!
Old 05-04-2021, 10:27 AM
The cast rods as was said are all basically the same.
The rubber rods were the Forged Rods that were made from inferior steel and not heat-treated and machined like the 421 SD forged Rods. Those were offered for a few years in the early 1960s. Wide Forging line on the side of the rod.
If you have a rod with a casting line on the side, like Mike Davis posted, then it is a cast rod and all the same basically for all engine applications.
Even the Forged Chinese rods, many times, are better than those forged "Rubber" rods.
"There is nothing more fun than Learning"
Barney Navarro (Engineer, Fabricator, Machinist,
Racer, Inventor, one of the Original "Boost Guys"
If you are Talking, You are not "Listening", you can only LEARN by LISTENING. LLM
Old 05-04-2021, 11:36 AM
The 990 Crank was only fordge for usage in the SD motors, and I can guarantee you that none, zip zero ever found there way into a production line 421![/QUOTE]
Steve, what's so special about the 990 cranks? Didn't they still have the 3.25 journals with oiling issues?
Cold Case Radiators
Cold Case Radiators is a Max Performance company that produces high end aluminum performance radiators at a price point that won't break the bank. Polished and stamped tanks. 2 rows of 1" tubes. Lifetime Warranty.
GTOG8TA.com
GTOG8TA.com is a Max Performance company that manufacturers parts for the 04-06 GTO, 08-09 G8, and 93-02 Firebird/Trans Am platforms.
