Old 03-29-2021, 04:30 PM
8453johng 8453johng is offline
Default trans am pacer car water pump hose ????
Hi
I have an 80 trans am pace car 301 turbo
I am looking for the coolant hose that one side ( 90 degree bend) connects to the water pump and
The other side makes a 90 degree bend and passes thru the ac compressor area
Is the factory hose still available??
If not what are people using
As Always Thank You
Old 03-30-2021, 10:02 AM
78w72 78w72 is offline
a factory correct hose is not made as far as i last knew but you can probably find one for another car with a similar 90* bend around the a/c compressor to work. or you can try to heat & bend one a little to get close but probably wont be perfect. see if some of your local parts stores will let you look at what they have in stock.
Old 04-01-2021, 08:36 PM
Default Thanks
went to parts store and found both bends and 2 steel couplers
Thread Tools
Display Modes
