SD Performance CNC Ported Heads Flow Data?
I have a 461 (400 block with 4.25” crank/4.15” bore) that has 6X8 heads that were given the CNC porting job at SD Performance (2010?) and I never received the flow sheets with the car that the engine was in. I think the CNC porting is to provide around 255 cfm (+/-) on the intakes and 200 cfm (+/-) on the exhaust, but at what lifts?. I'd love to know more what these heads can do.
Does anyone have flow data sheets they could post on similar SD CNC heads? Thanks! Dennis |
This might help.
Here another sample mine were done in 2018.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
Thank you Ponjohn! I believe 1.77 exhaust valves were installed as a part of the package? I never took the heads off to confirm. The engine has a Bullet hft cam 231/239 @ .050 .485"/.507" lift w/ 1.5 rockers and 112 lsa.
Dennis |
Dennis |
On Stans site pretty much shows Daves 260 CNC are at 600 lift and are usually in the higher 250s range no matter what D port iron head.Tom
Dennis |
Funny those two example images are cropped in just a manner to hide the exhaust valve sizes.. even on an angle .. lol
I gave up on another car until I get my intake manifold deal done!Tom
I wasn’t trying to hide anything other than my name on the print out. Here’s the full sheet if it matters? Sent from my iPhone using Tapatalk
Judging by Dave’s exh numbers hitting 200 cfm by .500” lift they must be reworked with 1.77” valves .
Do you know what level this SD ported iron intake is? SD has 3 levels: $175.00 CNC plenum + hand finish $275.00 CNC plenum + hand finish + port matched runners to std. intake gasket $375.00 CNC plenum + CNC port runners + hand finished (we've made over 600hp with these modifications!!!) I'm thinking these are the 2nd level ($275) with the CNC plenum and port matched runners to std. intake manifold gaskets. Thanks again! Dennis |
It looks like level 3 since the port match is to RA4 gasket size, not standard D port.
Dennis |
definitely RA4 ports on that intake, stage 3.
Wow that’s a nice intake looks like stage 3 to me
LOL! I should have just texted you about this. I never knew there was a difference in the iron intake modifications until I was looking into the head flow numbers on SD Performances website. So, this intake is the Stage 3...COOL! And thanks ga1979 for selling it to me! It's going to be installed on the 461 with the SD CNC 6X8 heads this summer replacing a stock iron intake...and a 800 cfm Q-jet.
Dennis |
Here's the SD CNC ported intake with RAIV/455HO/SD455 intake gaskets laid on it for comparison to the ports and some close-ups of the CNC work.
Dennis |
I port matched my stock iron 70 intake to a RA4 gasket and there wasnt much material left at the top(roof) of the port. I bet I only had about a 1/8" max. It seals though,,,I ground right to the edge of the gasket.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
