FS - Rodney Red Radiator 67-69 w/ electric fans
This setup has maybe 1500 miles on it. It is custom fit to bolt into a First gen firebird. I also had a bung welded into the tank for a thermal sensor and brackets to mount the electric fans. Has the internal trans cooler for automatic transmissions!
The electric fans are from a 1996 F-body and were the biggest that would fit on this massive radiator. Used the LT-1 stle fans because they have the bypass flaps for air to pass through at speed.
The adjustable temperature relay is installed and works but I would get a newer spal type controller and replace it if I was going to use this again.
The outside face was dusted with black paint to hide the aluminum from the front end view.
This setup can bolt in, wire up and go. Works very well! Inside is very clean, see pics. I used the anti-freeze specified for aluminum radiators and it tinted the inside orange! Let me know if you have questions.
$400 plus ship
