Old 08-24-2020, 08:49 AM
CLEL01 CLEL01 is offline
Default Fuel Pump No Vapor Return Line
What fuel pump that does not use vapor return and has the 5/8 invert flare output to carb and 3/8 hose input to pump? For 1964 GTO with no vapor return plumbing. Building 400 with 870 heads / Qjet with steel line from pump to carb.
Carter - Airtex all look to be with vapor return? Thanks for suggestions.
Old 08-24-2020, 09:06 AM
steve25 steve25 is offline
Ames performance the sponcers of this site list a pump N128PC that in there picture shows only 2 ports and is listed for 64 to 65 GTOs.
Old 08-24-2020, 01:21 PM
1968GTO421's Avatar
Great advice, you can look it up here:
https://secure.amesperf.com/catalogs/G36.pdf
page 197
GTOAA--https://www.gtoaa.org/
Old 08-24-2020, 06:33 PM
Thanks for the advise. I think my problem solved.
