SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
8.2 posi unit for high gear
posi unit for high gear ratio. I believe its fits from 256 to 336.
Posi worked good. Cones will fit in my 4 spider gear unit. $200.00 Firm {Worth saving for parts} The 4 spider gear unit is not for sale,just compare gear depth. |
I,m interested I have 336 gears
Just for clarification, the 2-series 2.56 posi unit shown above only fits 2.56 and 2.78 gears and will not fit any gears up to the 3.36 ratio.
There are 3 ranges of gears that all fit different 8.2" posi units (or open differentials). 2-series - 2.56 & 2.78 3-series - 2.93, 3.08 & 3.23 4-series - 3.36, 3.55, 3.73, 3.90, 4.11 & 4.33 Good luck with the sale. |
I wasn't sure I thought there were only 2 different . My mistake will need spacer. It measure about .335 thosands less than the other carier that is 355 carier
There is a 3 on carier.any identification or stamping can tell me by numbers
B-Man thanks
Youre welcome, I didn't want to see either of you (or anyone else) have trouble doing a deal with a part that was not properly ID'd as to the application. |
A 3 series 4 pinion was made for GP models.
Is there a 101 102 or 103 cast in the carrier? How many bolts are holding the case halves together, 6 or 8 (looks like an 8). Stood on a very flat surface as positioned in image, what is the dimension up to the ring gear flange? Condition of spiders and side gears?
Gregg V. |
I am on the watch for a good series 2 posi unit to work with my 2.78 gear. A bit confused- is that what you have? What gear was on it? Is that what the other posters are looking for?
Walt
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi 1974 455 TA, admiralty blue/red interior HPP "cover car" - sold "The best way to show a car is to drive it" |
I wrote wrong its about .375 or 3/8 difference from other carier. And it has 8 bolts that splits carier not 6. I will take more pics and split carier to see what cones and gears look like and i will post pics.
I'm glad I pulled apart look likes spiders were broke before.Axle gears have marks .The 2 spider gears look good.Cones look good but have nicks.The small pin in th spider gear pin doesn't look factory.The 2 steel covers that cover the 3 springs has nicks and gouges.
more pics.
Sorry for getting anybody hopes up. Like i side it did work in car. I thought it was OK. |
gone
