1978 ta tilt steering hub
My car got stolen and recovered looking for a 78 tilt steering hub black if possible
the steering wheel hubs are the same for tilt or non tilt columns. i have a bunch of these hubs, most need repainted. Pm if interested.
When a Saginaw steering column of this era is damaged from someone stealing the car, the potmetal cast lower bowl is usually what is destroyed. The upper bowl which contains the lock assembly on a 69+ GM column can also often be damaged. For near two decades I sourced Saginaw tilts & hard to find floor shift column cores & core parts.
The upper "bowl" is functionally the same on most '69 to late '70's GM tilts. There are exceptions like the mid seventies upper line Pontiac A-body tilt upper bowl which has the supplemental thin plastic cover that bulges out the LH side with turn signal lever. on the '69+ early upper bowls, they were cast of pot metal, the later usages of this style upper "bowl" is made out of a hard plastic. There are a few variations with only minute appearance issues between them.. Other early steering column terminology: Early straight columns consisted of a lower bowl & an upper "cover". There are MANY different versions of lower bowls & upper "covers". Saginaw manufactured columns for not just GM, but other manufacturer's vehicles. the term "hub" is typically used for the cast part that bolts to a specific to a certain style optional steeing wheel & is tightened to the upper shaft of the steering column. Some examples: -Late '69- 81 Formula style wheel, all had the finely textured tall hub. -Buick GS 3 spokes/Chevelle/ '69 Camaro 3 spokes/Chevelle/C3 Corvette, etc -SuperStock Olds style Sport wheels
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 10-02-2022 at 12:15 PM. |
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post: | ||
The upper bowl
I just pulled the Tilt Column out of the 78 Catalina Parts car I am stripping Would this have the same upper cast Bowl? If so I will get some pictures to see if you are interested. If you are you can have it for the price of shipping and a Beer.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
I hope it the same im.not sure
The tilt column upper bowl should be the same as long as the upper bowl is not like the upper bowl on a '79-81 Firebird tilt.
Do seem to remember that downsized Catalina/Bonneville bodystyle going somewhat fairly early to the dimmer switch/directional signal style bowl.
In the house for lunch. Original dated Pontiac Master Parts Books shows '78 Pontiac B series tilt as having same housing kit (upper bowl ass) as '79-81 F w tilt.
part you need was used on '77-78 Firebird tilt columns.
It sounds like its the wrong part for you car, but here are some pictures of the 78 Catalina Tilt Column I have.
I appreciate it but that one looks different than mine thank you for trying to help me
No problem, I wish it would have worked out
Thread Tools | |
Display Modes | |
