Old 10-02-2022, 03:01 PM
grd777 grd777 is offline
Default need help to I.D these brackets
toke this off a a/c compressor by not sure which car they came off . i think it was a 79 car
Name:	IMG_5667 (002).jpg
Old 10-02-2022, 05:22 PM
George, both were off small block Chevy V8, early '70's up til aprox '81 in Cars & '73+ Pickups. That style brackets were originally used with the tall style small block water pump & A6 compressor when AC equipped.
Mid '80's through the late 90's i regularly pulled gobs of muscle era 60's Chevy V8 brackets & pulleys, bolts, spacers; '67-72 Chevy pickup, '65-67 ChevyII alt/ps/rams horns manifolds, common '65-68 small block pump/bracket/pulley setups. Some big block brackets & pulleys, often big block stuff a piece at a time. A bunch of the more common of these pieces ended up being reproduced. For a good while, even the common short water pump pieces sold very well.
Old 10-02-2022, 05:44 PM
thank you again for our help
Old 10-02-2022, 10:35 PM
Trevor78 Trevor78 is offline
#351690 / 458523 for the top.
#3932433 for the bottom.
A NOS set of just these brackets!
https://autopartsobsolete.com/images...cts/202029.JPG
