International shipping can get pricey.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
The Following User Says Thank You to jhein For This Useful Post: | ||
Here are the plug wire holders painted with a zinc/cadmium paint (L) and Eastwood Spray Gray to mimic bare steel (R). I'm thinking the zinc holder looks more original. Any opinions or suggestions for a closer OEM finish?
I vote for zinc.
There is a great thread about zinc plating that I bookmarked a while back. HERE, I found the thread for you!
Did I miss the thread link?
It's ebeded in the word (look for all caps; blue, and underlined).
Nothing I see is all caps, blue or underlined
The two 4-wire holders that are closest to the distributor mount to unique threaded holes in the rear of each head and do not share that position with any other brackets?
Also, the driver's side middle 4-wire holder has a square base, where all the others on the valve covers are rounded to fit snugly. Why? I am having trouble fitting that wire holder onto the DS rear lower valve cover bolt and I'm wondering if it attaches elsewhere. |
The Following User Says Thank You to Jimbobeast For This Useful Post: | ||
Well, I'm embarrassed because I said previously that it mounted to the valve cover. But, you've jogged my memory now and I believe the second 4 wire loom on the drivers side does not mount to the VC. It mounts to a hole on a boss on the head just below the VC. And yes, it's the one with the square base.
I'll post some pictures tomorrow guys;
hopefully that will add clarity on this.
Here are the pictures I just took;
One for each side, showing the rear most (four wire) holder, and one for each side showing the wire holder along with it's bolt/attachment location. These locations are the same for RAIV engines; This is my YZ RAIII; The non-RA engines had the additional holder (not for spark plug wires) on the rear outer driver side valve cover bolt; My WT engine isn't nearly as "pretty" as my YZ - as that engine will get rebuilt or at least refreshed before I run it, so I am holding off on painting it... and the 67-70 Pontiac is nearly unobtainable north of the 49th.
The Following User Says Thank You to unruhjonny For This Useful Post: | ||
The drivers side rear are hard to see with the motor in the car. These are a little clearer.
My finished wire holders.
Here's a nit-picky question: on the two 4-wire holders closest to the distributor, they each have a long arm and a short arm (the mounting post is off-center). Do they mount with the long arm pointing forward or back? |
Looking more closely at pics from unruhjonny and myself, it seems like the rear-most looms are the same, so when you mount them on opposite sides of the motor, the long side faces the opposite direction, if that makes sense. So the one one the driver side, the long side goes forward, on the passenger side the long side goes back.. Actually, I think it's the only way you can mount them, the 'flat' side of the bracket has to go up against the head.
That makes sense.
as John said, they only mount (or fit) one way;
on the drivers side it mounts directly to the head - if flipped it wil not fit; on the passenger side, that same mounting spot is used for an emmissions device, so the bracket moves to the rear most intake bolt - and again, it can only fit one way there.
Apparently, my car is missing said emission device. They got it close but lots of details are missing...
oh, I have ample time to stew on the details...
Now if I just had the time (ect) to get the metal "surgery" done so I could get back to having fun in my car!
#38
I'm rooting for you.
#39
The rear passenger side 4-wire holder nearest the distributor seems to fit perfectly sharing the attachment bolt with the TCS spark bracket. It is then symmetrical side to side and looks good. I will attempt some photos. That's my story and I'm sticking to it.
Jhein, I've got a bunch of the TCS switches/brackets just lying around if you want one. |
#40
well I guess you can put it where ever you want.
I have documented it there as being where I suggested it go on engines I have pulled these parts off of, and then there's documentation like this.
