Old 12-23-2019, 02:29 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Default Single-plane Tri-Power?
I've put a lot of miles on Tri-Power Pontiac engines, but all with factory dual-plane manifolds. I often wonder how a single-plane Tri-Power manifold would perform (I think I asked on this forum quite a while ago but didn't get answers). I recently noticed that the Offenhauser 360 Equa-Flow manifold (1968 era) was a single-plane and available for three 2-bbls and (I think) available for Pontiac. Anybody here ever run one?
Old 12-23-2019, 11:37 PM
I had two of the earlier 64 head Offy Tri-Power Intakes.
The intakes were actually pretty good about airflow thru the short runners and divided plenum. I cut one apart one time and there were a couple of "windows" between the two side by side plenums. So they fit the 360 manifold definition.
Not sure what the application was on the one I cut apart. Maybe sb chevy or sb ford.
Many many years ago.
The Pontiac intake I flowed on the SF 1200 flow bench, flowed about 270 cfm thru one short port.
Old 12-24-2019, 01:22 AM
Is the "360" manifold less satisfactory for everyday street use (mostly center 2-bbl) than a dual-plane manifold?
Old 12-24-2019, 06:55 PM
The 360 manifold would operate like a 780 Holley 4 BBL's primaries on a single plane intake. A bit soft on the bottom end and maybe a bit more tuning required vs the calibration the Rochester Engineers put into the Factory Tri-Power 2 BBL but still not a big issue vs not running one of the things.
Old 12-25-2019, 01:34 AM
Thanks. Merry Christmas.
Old 12-28-2019, 01:49 AM
I "thought" that Offy made the 360 3-2bbl manifold because their ad in January '68 Hot Rod said "...1, 2, and 3 carb" versions. However, after January they never again mentioned a 3 carb 360 manifold, just single- and dual-quad.
So... I suspect that nobody ever made a single-plane 3 2-bbl manifold for Pontiac... and maybe not for any engine.
Old 12-28-2019, 01:57 PM
brut4s's Avatar
brut4s brut4s is offline
I don't know if you saw this but if not here you go the only single plane Tri-Power I know of for a Pontiac
https://headsandmanifolds.wordpress....3000-7500-rpm/
Old 12-28-2019, 10:03 PM
Jack, if you cut the top off of a 64 type Offy Tri-Power Intake I believe you will see the "communication windows" that basically make it act like a dual plane 4 bbl intake but with the plenum divider removed. Both barrels of each 2 bbl carb get the same signal at the same time.
Old 12-29-2019, 03:23 AM
Originally Posted by brut4s View Post
... the only single plane Tri-Power I know of for a Pontiac...
Thanks for the link- I had not seen that. I'm sure Dave Wilcox has created a great manifold... but pricey. Nevertheless it interests me. An apples-to-apples test (dyno or track) would be good.
Old 12-29-2019, 03:03 PM
Dave Wilcox did a very nice job porting my "Barry Grant 6-Shooter" (TRI-POWER) intake but the cost was not cheap, just like the single plane TRI-POWER intakes he is selling.
Old 12-30-2019, 12:04 AM
433lemans's Avatar
433lemans 433lemans is offline
Been following this for some time but it sure would be nice to "see" this manifold! No pics on the website yet unless I missed it?
Old 01-07-2020, 10:05 PM
433lemans's Avatar
Who has seen it? It doesn't exist without pictures! Let's see it.
Old 01-08-2020, 08:23 AM
brut4s's Avatar
I'd like to see it also
Old 11-03-2021, 09:05 PM
433lemans's Avatar
Default bump
Been plenty of time. Let's see it!
Old 11-04-2021, 05:45 PM
misterp266's Avatar
Default Offy 360 tri power
Isn’t this a single plane intake?
https://www.ebay.com/itm/35354808243...BoCmCoQAvD_BwE
Here’s another.
http://hotrodcarbs.com/store/offenha...-manifold.html
ID:	576928   Click image for larger version
" Darksiders Rule "
Old 11-05-2021, 02:16 AM
Yes, that appears to be the Offenhauser Equa-Flow that I mentioned in the original post of this thread. I'm still wondering if anyone here ever ran it?
Old 12-22-2021, 06:29 PM
brut4s's Avatar
Troy Patterson (tmp carbs) is making one.
https://www.facebook.com/14380661198...3501/?sfnsn=mo
Old 12-22-2021, 06:32 PM
brut4s's Avatar
Here are pics for those thay don't have Facebook
ID:	580389   Click image for larger version
ID:	580390   Click image for larger version
Old 12-22-2021, 07:34 PM
tom s tom s is offline
Does that intake look like a modded Offy 2-4 intake?Tom
Old 12-22-2021, 08:05 PM
brut4s's Avatar
Looks like it to me too.
