Old 03-11-2023, 07:19 PM
400 Lemans's Avatar
Hard to read but the one at the top is your cam, i believe.
Name:	crane cam (1).jpg
The Following User Says Thank You to 400 Lemans For This Useful Post:
  #102
Old 03-12-2023, 03:37 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
I appreciate you looking at this.. Yes, I think you are right. I wonder if it's even as much cam as original?
Anyway, the way the exhaust sounded when I listened to the video of it running before he removed it from his car bears this out. Very smooth and definitely no lope at all.
It's all okay though because my objective isn't performance. If it was I would probably spend several more thousand building a 400 or 455. The more I think about it, I will probably just leave it as is. Maybe even remove the 4 bbl and use my 2 bbl manifold with rebuilt carb. A new cam might mean different push rods and possibly valve springs... I just don't want to put a lot of money into a ho-humm engine when I already have one that, though not powerful, runs decent... Similar to how the original once did.
The Following User Says Thank You to 79 Phoenix For This Useful Post:
  #103
Old 03-17-2023, 03:42 PM
79 Phoenix's Avatar
Default Door Panel Question
Well, I have gotten nothing done this week. Out of town 2 days and sick the rest!
But I did sell my driver's door that was beyond my capability to fix. In removing the door panel, it is apparent that the vinyl surface is actually in good shape. The cardboard behind is warped. It doesn't show much in the picture but does show when it's mounted on the door. QUESTIONS:
1) Is there a way to flatten the cardboard back out?
2) If I re-mounted the vinyl on a flat cardboard, would cardboard from another A Body door panel work? , Which models and years would have the same cardboard as the Pontiac? I know where there are some Olds Cutlass and Chevelles...Maybe a Skylark...
I'm going to stick the new door (purple)on temporarily and then get back to work underneath the car.
ID:	608999   Click image for larger version
ID:	609000   Click image for larger version
Name:	NEW DRIVER DOOR.jpg
  #104
Old 03-17-2023, 03:59 PM
I would use another material - poly signboard may be a good candidate.
Why use something that is guaranteed to warp?
  #105
Old 03-17-2023, 04:29 PM
79 Phoenix's Avatar
You mean the stuff they use for yard signs? Sounds like a great idea.
  #106
Old 03-17-2023, 06:37 PM
not quite, thin 0.150" with a foam core. A sign shop may have it for sale.
  #107
Old 03-17-2023, 06:56 PM
79 Phoenix's Avatar
Okay, thanks. I know just where to go when the time comes. I appreciate your input!
  #108
Old 04-12-2023, 08:07 PM
79 Phoenix's Avatar
Default PLASTIC REAR VALENCE
Well, I'm back after being sick with covid and a sinus infection for 3 weeks--then out of town for 3 weeks...
I plan on being at spring Carlisle in a couple weeks and I want to take advantage of Ames' free shipping for orders made in advance. I hopefully will get the rear bumper off tomorrow and want to see if it can be re-chromed. If not I plan on ordering a new one from Ames along with some other stuff I will be needing.
One of the things I'll be needing is a new rear valence with cutouts. Has anyone used one of the plastic ones? I understand the edges are flat (straight) not curved. Anyone have a picture of one installed?
  #109
Old 04-13-2023, 08:40 PM
79 Phoenix's Avatar
Removed what was left of the rear valence and the rear bumper. Took the bumper to a chroming place. Not surprised but it's too far gone to re-chrome (deeply pitted) As first photo shows, last time my GT-37 was on the road was 1992.
Has anyone used one of the plastic rear valences? I understand the edges are flat (straight) not contoured with qtr panel.. Anyone have a picture of one installed?
ID:	610692   Click image for larger version
  #110
Old 04-16-2023, 11:49 AM
Skidmark Skidmark is offline
So this plastic valance is original (I believe) to my 72 lemans sport. It's definitely worn out, cracked, and broken and appears to have come with the car when new.
I'm pushing the driver's side up because the tab is broken, to give you and accurate depiction of the gap. Passenger side is not broke.
I purchased a repo years ago from NPD. Wasn't impressed with the quality, but might still use. When I repaint the car I am going to see about using a metal valance.
I can dig out the repo one if needed and take a picture ( if I can find it lol).
You can see that the gap is quite substantial, at least in my case.
ID:	610816   Click image for larger version
  #111
Old 04-16-2023, 12:14 PM
GT-37's used the metal "GTO" rear valance, they're reproduced cheap, & fit fine.
Most '72 LeMans came with plastic (no cutout) rear valances, many of them were damaged early on & replaced with the no cutout '70-71 style rear valance.
  #112
Old 04-16-2023, 12:27 PM
79 Phoenix's Avatar
Thanks for the pictures. I think the repro plastic ones are flat on the ends not contoured like your original one. Confirms my decision to go with a metal repro from Ames.
  #113
Old 04-16-2023, 12:31 PM
79 Phoenix's Avatar
Yes thanks for that info. I ordered a metal one from Ames. They say the fit is pretty good. I'll be picking it up this Friday at Spring Carlisle along iwth a bunch of other stuff..
  #114
Old 04-20-2023, 07:11 PM
79 Phoenix's Avatar
I've been struggling getting the upper bolts off my rear shocks, but I'll get there.
Meanwhile my brother helped me put my "new" door on today. Lots more work to do on the door but I can do it while on the car. Right now concentrating on underneath the car.
Tomorrow, off to Carlisle!
ID:	611083   Click image for larger version
  #115
Old 04-21-2023, 03:37 PM
vertigto's Avatar
vertigto vertigto is offline
Nah...those shocks are fine.
The Following 2 Users Say Thank You to vertigto For This Useful Post:
  #116
Old 04-25-2023, 10:36 AM
79 Phoenix's Avatar
Probably installed in the 80's. I considered wrapping soda cans around them and painting to look like new... but thought better of it!
  #117
Old 04-25-2023, 10:43 AM
79 Phoenix's Avatar
Picked up some needed parts at Carlisle last week...rear bumper and valence, weatherstripping and battery tray, door panel boards--all from Ames. Also got some rubber door bumpers from Restoration Specialties and a decent used LH taillight lens to replace my broken one.
Hope to get two "New" repairable front fenders this week.
  #118
Old 04-25-2023, 11:17 AM
Whoa, good used car salesman idea there...
  #119
Old 04-30-2023, 08:45 PM
79 Phoenix's Avatar
Default 77 Can Am Wheels
Question: Should 15 X 7 wheels off a 77 Can Am have 4 3/4" bolt pattern?
  #120
Old 05-01-2023, 12:04 PM
Yes , they would.
And Can Am had White & Silver paint scheme on their R2 wheels.
