73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 11-08-2007, 08:10 PM
rickw rickw is offline
Default "Making" a 73 GTO hood questions
Since 73 GTO hoods are hard to come by, I've decided to make one. I have several of orig plastic inserts, but I sure could use a good template to follow or some good close-up pictures... Also would love to see a photo of the underside to see exactly how the inserts mounted at the factory. I'll be trying this first on my 71 Grand Prix, then move to my 75 Sport Lemans. Thanks in advance. (if anyone has some scoops cut off a real hood... sure would save me from tinkering and bending)....
Old 11-08-2007, 08:57 PM
JKGTO's Avatar
JKGTO JKGTO is offline
You can plasma cut the scoop openings out but there is also a lip around the openings because the hoods were stamped out. Would be hard to duplicate but 9 out of 10 people would never notice. Where are you located? I can help you with this project and have a few spare parts also. Jim
74 LEMANS GT 350 4SPD MAROON
Old 11-09-2007, 12:06 AM
2 73's 2 73's is offline
rickw, here's a picture of a hood that had the scoop section taken out of one hood an put back into another hood, take note of the lip as Jim stated.
If nobody posts a pic of the underside, I will try an put one up for you by tomorrow night.
Old 11-09-2007, 07:19 AM
Default hood openings
I want to do this right, so I guess I'll have to cut just inside of my mark and roll the edges inward with welded corners. Won't have the hard edge the factory got but should look OK. Jim... when you say you have extra pieces?....
I found a 73 Lemans GT with the right hood, but hate parting a nice car, and it's 1100 miles away.
Old 11-09-2007, 10:57 AM
sport coupe sport coupe is offline
Default GTO hood inside
A lot of work to make it look like this.
Old 11-09-2007, 12:13 PM
Default Hood pans
I plan on just coming up with a simple set of brackets to hold the inserts and cut sheet piece of aluminum to funnel incoming moisture to the back and out a tube on the passenger side past the tranny... sounds like a good project for snowy days here in Texas....
Old 11-09-2007, 10:36 PM
JKGTO's Avatar
I do have the hood section that is in sport coupes picture. I dont have any scoop inserts. A '75 hood wont have the cowl vents in it either. Jim
Old 11-09-2007, 10:59 PM
So Jim, what are the chances that you might sell the scoop section? I already have 3 inserts. If I could afford to buy a 73 GTO I would. Just going about it in a round-a-bout way. BTW, and for the record, I have NO intentions of every putting a GTO emblem in this car, don't mind cloning a look, but a lie is a lie.
Old 11-09-2007, 11:04 PM
Dang!! should of checked the thread before I uploaded the pic's.
Old 11-10-2007, 10:14 AM
JKGTO's Avatar
I will dig that out today and get you a picture of it. If still interested you can PM me and I will give you a price. Jim
Old 11-10-2007, 01:33 PM
JKGTO's Avatar
Picture of hood pieces I have. Jim
Name:	73 GTO HOOD CUTOUT.JPG
Old 11-10-2007, 06:24 PM
myam myam is offline
Default Making a 73 GTO hood
Just a small note to pass on. The small indentations around the NASA inserts were the location holes to screw on the upper plentum for the RAM AIR system. Evadently it was in the works as a possibility on these cars with this hood.I think a total of 7 screws held it in place.
Old 11-13-2007, 11:29 PM
Jim, shoot me a price.... even though.... I bought the 75 Grand Am off craigslist in Austin this morning (it has a 73 GTO hood, see: austin.craigslist.org/car/476777604.html). I still plan on giving my 71 GP the NACA scoop treatment though. It's going to be a busy winter, but a good one. This next part you will not believe, and neither will I until I see it– owner told me on the phone that this car has a working RA system under the hood with vented flaps and air cleaner seals. Guessing it's a home-made ordeal, if anything at all.
Old 02-07-2008, 09:19 PM
71HOT/A 71HOT/A is offline
How much are nice 73 GTO hoods going for ?
Old 02-08-2008, 06:27 AM
Usually between 3-5 hundred, pending on condition.
Old 02-08-2008, 08:21 PM
Default Making a 73GTO hood
Thats pretty interesting. I'd like to see pictures of this system. I wonder how close it is to original designs?
