Old 04-07-2009, 08:06 PM
1971/455/HO/4-SPD's Avatar
1971/455/HO/4-SPD 1971/455/HO/4-SPD is offline
Default 4X heads/Date Codes
I have a pair of 4X heads with date codes of what appears to be H152 and G272. What do they belong to and what are the date codes? Thank you!!!
Old 04-07-2009, 09:32 PM
1qikta's Avatar
1qikta 1qikta is offline
July 27th 1972 Casting
August 15th 1972 Casting
They would prob be on a 1973 model car. Check the ends of the bosses on each head. You would have 1h,4h,3h or 7h as a secondary code. That will tell a lot about what exact engine and trans they came on..
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
Old 04-07-2009, 11:13 PM
455 Correct?
Old 04-07-2009, 11:22 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
See this site...
http://www.wallaceracing.com/head1.htm
Old 04-08-2009, 08:53 AM
1qikta's Avatar
1h is a 455 4bbl auto
4h is a 400 2bbl auto
3h is a 400 4 bbl auto
7h is a 400 4bbl 4 speed.
98-112cc's most all have screw in studs after march or so of '73. Only the 3h and 7h will have screw in studs prior to march.
Old 04-08-2009, 09:05 AM
Thanks guys!
Old 04-08-2009, 04:58 PM
There was a 7 stamped on the horizontal underside of the bossing on both heads, no H however? Are these worth anything to anyone? I assume they are from a 400 4-spd 1973? I got them with a car purchase last year, just never checked them out!
Old 04-08-2009, 05:14 PM
1qikta's Avatar
Are you looking here?
This is a 4X 455 head...1H.
ID:	164767   Click image for larger version
ID:	164768   Click image for larger version
Old 04-08-2009, 05:16 PM
That's where the 7 is, but I don't see an H. There is surface rust however, but the 7 sticks out like a sore thumb!
Old 04-08-2009, 05:29 PM
1qikta's Avatar
Its a 400 head for sure then...are you selling them?
Old 04-08-2009, 06:43 PM
Yes, I will put them up for sale for anyone interested!
Old 04-11-2009, 04:03 PM
TransAmRIP's Avatar
TransAmRIP TransAmRIP is offline
The following are 73-74 heads
4X-1H uses 4.881/4.870" valves
4X-1H are 455 head with 114cc, 2.11/1.66" valves and pressed studs.
4X-3H are 400 4bbl head with manual transmission, 98cc, 2.11/1.66" valves and screw-in studs.
4X-4H are 400 2bbl head, 1.96/1.66" valves and pressed studs.
4X-7H are 400 4bbl with auto trans, 98cc, 2.11/1.66" and screw-in studs.
46 are 350 2bbl/4bbl heads with about 86cc, 1.96/1.66" valves and pressed studs.
4C-5 are 350 with AIR, 1.96/1.66" 86cc, pressed stud.
4C-9 are 400 with AIR, 1.96/1.66", 98 cc, pressed stud.
Is this info correct for these heads???
1974 400 4 speed
Old 04-11-2009, 07:42 PM
From the sources I have seen, I don't think they designate between auto or 4-spd????
Old 04-11-2009, 08:25 PM
1qikta's Avatar
Bub,
Sorry if you think I mislead you. At the time I was going from Rockys article.
http://www.highperformancepontiac.co...ads/index.html
But lately, I have just about decided that all the 7h heads I have dealt with have slightly smaller chambers. Most around 98cc's. Seems the 3hs average about 102-103cc's.It would make sense that the 4 speed cars would get the smaller chambers.
Its just my observation.No need to sell your heads. Rocky knows his stuff for sure.
Old 04-12-2009, 05:35 AM
TransAmRIP's Avatar
Bub,
Oh no Jay not at all, I just want to make sure I can use the heads that I currently have
or if I would need to change to something else to match my engine
Thanks for clearing it up,
Bub.
1974 400 4 speed
