Power antenna
I have an early production 65 Lemans with a lot of options. It has a power antenna coming out at an angle on the RR between the trunk and the quarter panel, factory with the factory switch on the dash.
I can hear the motor running with the switch on up or down, but no movement on the mast. I can pull the antenna up and down only a few inches. I expect I need the nylon insert that goes inside to move the mast. Or maybe a gear ? I haven't been able to find any parts, so hoping I can fix the original. |
If you run the switch and hear a clicking in the motor, sounds like the nylon is frozen. Most likely you'll have to replace the mast w/nylon. There are not easy to find and expensive when you do.
Practicing social distancing for 65+ years |
There is a guy in the Tampa Bay Area. I believe he refurbishes them. I bought one from him. It was excellent. He might be able to do something for yours. His name is Frank and he is a member here. I can’t remember his user name. You can PM me if you would like his contact info.
No clicking sound, just the motor running. Up or down just the motor running.
Power Antenna
I believe the part number for the correct mast for an A body is 541963. A lot of people run the longer B body masts because they’re a little easier to come by Eric
I can look for the part number on the antenna body. Thanks! |
Careful going under low bridges.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
That's got to be it then. I was very surprised when it kept going and going! Thanks.
His number is 352-688-8199.
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
Thread Tools | |
Display Modes | |
