Old 06-07-2021, 09:36 PM
rod cole rod cole is offline
Default recommended spring pressure
comp 4136b intake 4137b exhaust 270 duration at .050 and .430 lobe lift approx .700+ at valve thanks Rod
Old 06-07-2021, 10:51 PM
tom s tom s is online now
What does the maker recommend?Tom
Old 06-08-2021, 05:55 AM
What heads are you running?
What lenght valves?
What's the max rpm this motor will need to spin to?
What ratio rockers will be used?
Old 06-08-2021, 06:28 AM
Steve C. Steve C. is offline
A fwiw, and information offered for general interest only. Joe Sherman posted this on Speed Talk involving a aggressive Comp RT lobe with well over 0.700" lift....
“Currently on dyno with a small block RT intake with a 1.65:1 rocker and 128g valve (I know it's heavy) and with a PAC 1385 set at 275lb seated and 660open. This thing is out of control by 7700...”
Note a small block Chevy valvetrain in use in that comment. Already eluded to in the above post, and that being the valvetrain mass and the RPM level involved here.
Old information here:
Old 06-08-2021, 11:20 AM
Scott Stoneburg's Avatar
I would definitely check the manufacturers recommendation. But a general number would be 325-340lbs on the seat and 650 lbs open.
