Trying to turn engine by hand
I'm trying to do a distributor on a 350 olds I've got all the plugs out of the block except the one under the AC compressor how hard will it be to turn the engine by breaker bar to get it to tdc cause I know I have to do that
Sent from my SM-S111DL using Tapatalk |
With 7 plugs removed, pretty damn easy, you should be able to use a standard 1/2" ratchet with no compression on any cylinder but one. A breaker bar would be overkill.
You can turn an engine with all 8 plugs in. It's slow but it turns, not spins.
Whelp got it out distributor was fine this engine is toast!
