Old 04-13-2021, 09:06 PM
gtorich gtorich is offline
Default 3/8-24 all threaded bolt Grade 8
Long story short, got my umi lower control arms, they supply a 4 inch bolt to hook you end links into.............seems i need one maybe 5-6 inches long. Umi suggested getting a longer bolt.............so far i cant seem to locate one, not sure im putting the info properly in the puter...........can anyone help out here.
Just to be clear, it must be all thread
Rich
Old 04-13-2021, 09:18 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Not likely to find a bolt like that.
What about a piece of all thread.
You could tack weld a nut on 1 end. or use red lock tight.
JM2C's
Old 04-13-2021, 09:22 PM
Grainger
McMaster-Carr
Old 04-13-2021, 09:36 PM
Thanks johnta...........gotta double check those again, looked at them and couldnt find any over 4 inches full threaded..........guess there called tap bolts.
Old 04-14-2021, 07:12 AM
When I was on that page it had them to 6" or so?
EDIT:
You are right, after a certain length they went to partial.
Try this for the all thread:
McMaster-Carr
Old 04-14-2021, 10:03 AM
mgarblik mgarblik is offline
Although "all thread" type rod can be used and will work, it shouldn't be necessary. When you are building up your "sandwich" of the 4 bushings and washers, it often looks likes it's impossible to get a nut started. However, the "sandwich" is operated in tension. Have an assistant with a long bar pry down on the stabilizer bar near the end and then you can usually get the nut started. once started, it will quickly compress the bushings and go together without leaving a long, ugly stud end hanging out. Good luck.
Old 04-14-2021, 08:22 PM
Hey Mike, i"ll send you a email on what im doing
Rich
Old 04-14-2021, 09:49 PM
Another thought on this, can you take a longer partially threaded grade 8 bolt and have a machine shop make it into a full threaded bolt.
Rich
Old 04-15-2021, 06:08 AM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
Fastenal lists a 5 1/2" but calls it a tap bolt.
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 04-15-2021, 09:34 AM
Hey Jim, ive seen that in the Fastenal book, but that is a grade 5...........not sure if this is strong enough for the end links....pic of what i have going on here.
Rich
Name:	end link 1.jpg
Old 04-15-2021, 01:11 PM
I see now. I assumed you had stock links. I think 3/8-24 hardened all thread rod would work fine in this application.
Old 04-15-2021, 01:41 PM
dataway's Avatar
dataway dataway is offline
Now I see .... if you absolutely cannot find the right bolt ... I'd use the grade 8 rod with a nut TIG welded to the top.
Old 04-15-2021, 04:06 PM
Hey thanks Mike & dataway...............i can get the threaded rod but they said two weeks out.............i did find a 5 1/2 grade 5 at Fastenal.........any thoughts on that one.
So i take it you cant take a longer grade 8 bolt that is partially threaded and get a machine shop to make it into a total thread.
Rich
