Old 05-09-2021, 06:59 PM
JJDeville JJDeville is offline
Default Back up lights
I have a 64 GTO that came with back up lights in the rear bumper. I bought a rechromed bumper a few years ago that did not have the holes for back up lights. My original bumper is a little rough but could be straightened out if I have to. My question is this, did the dealer cut holes in the rear bumper with a hole saw to install back up lights if customer wanted them as a dealer installed accessory? At the factory when they were installed on the line were there two different bumpers? One with back up lights and one without? Thanks for the help!
Old 05-09-2021, 07:10 PM
Jeff Hamlin's Avatar
Yes, the Dealer Kits came with a Template.
The one shown below was from a '65 kit I picked up years ago
Old 05-09-2021, 07:16 PM
lucky1 lucky1 is offline
Default Back up Lts.
Never knew Dealers did that.
Old 05-10-2021, 06:30 AM
I'm sure there were bumpers pre-punched with advanced knowledge of BU lights being ordered.
I have also seen where some cars received a punched bumper but did not have BU lights. In this case,
the factory had/used a chrome cap/cover.
These are VHTF, to say the least.
Note where they mention the Greenlee hole punch, These are still used today.
Name:	65 NO HOLE BUMPER.jpg
ID:	566288   Click image for larger version
Name:	65 BU LT PLUGS-CAPS.jpg
ID:	566289   Click image for larger version
Name:	INSTALL SHEET (3)x.jpg
ID:	566290   Click image for larger version
Name:	1 FULL VIEW x.jpg
ID:	566292   Click image for larger version
Name:	HOLE PUNCH KIT.jpg
Old 05-10-2021, 08:48 AM
Rich-Tripower's Avatar
I cannot imagine using a Greenlee punch on something as thick as a bumper. I also would imagine the chrome would begin to peel at the edges of the cut hole after a few years.
Old 05-10-2021, 09:17 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Anybody ever tried putting the back up light protector plates in with removing the bumper bracket??
64 Lemans hardtop
4spd, buckets
Old 05-10-2021, 11:03 AM
65 421 TODD's Avatar
65 421 TODD 65 421 TODD is offline
Back in 1976 the '65 Tempest Bumpers where still available from Pontiac I bought one. It came in without the holes for Backup Lights. I took it along with my old original bumper to a machine shop, they cut the backup light holes perfect.
Old 05-10-2021, 01:16 PM
JC61's Avatar
JC61 JC61 is offline
I was working for a Pontiac dealer from 1964-1965. I installed back up light assembly on a 1963 Cat.
After locating the correct placement, I drilled a hole and used a factory tool which then punched out the correct diameter.
The tool was two pieces one went on the inside of the bumper and the other attached on the outside.
It was tightened with a wrench until it punched out the correct size the back up light was plugged into the existing harness.
Old 05-11-2021, 06:06 AM
IIRC The shields can be easily installed without dropping the bumper.
I'll have to crawl under the '65's at the shop to re-confirm.
ID:	566368   Click image for larger version
Name:	65 BU LT SHEILDS.jpg
ID:	566369   Click image for larger version
Name:	65 BU LT SHEILD DS.jpg
ID:	566370   Click image for larger version
Name:	65 BU LT SHEILD PS.jpg
Old 05-11-2021, 11:45 AM
I don't know about a 65, but I was easily able to install the shields on our 64 without removing anything.
Old 05-11-2021, 11:43 PM
Lemans64's Avatar
Not intending to steal the thread, but mine is a 64, had it on hoist and thought it looked bad so left it off.
1 bolt is easy and the other looks to be between fuel tank and rear cross member. never really tried that hard.
64 Lemans hardtop
4spd, buckets
Old 05-12-2021, 06:26 PM
bill ryder's Avatar
bill ryder bill ryder is offline
On my 65, had both of mine off and on last winter to install refurbished back up lights. Small arms and hands help..
"Bill"!
