Old 05-24-2021, 07:56 PM
blueghoast's Avatar
Originally Posted by GTOGEORGE View Post
120-130 seems to be low for that compression.
GTO George
Thats what I thought to, I beleive it's got to do with the cam events.
Though it does seam low with that much compression huh.
GT
  #62
Old 06-02-2021, 05:44 PM
Anderson Port Development's Avatar
Anderson Port Development Anderson Port Development is offline
Originally Posted by Mike S View Post
Want to know if it is possible to make 700hp on pump gas with a factory block.
I am thinking of changing the heads for next year. Going from 330cfm to 380 cfm and of course a cam change. Need peak hp to be around 6500rpm. Right now I am running 12-1 comp with 72 cc heads. Looking at 80cc to drop comp 1 point.
The short block is factory, filled to the water pump holes, billet 4 bolt mains, forged 4.21 crank, lifter bore brace, crower rods and 60 over ross pistons.
Goal is to run what I am running now but on pump gas. 10.00/133 at 3400lbs in the heat of summer.
... this is my 10.6 to 1 428 build, CV-1's and 93 octane, it made well over 700hp ...
... simple combo really ...
ID:	567596   Click image for larger version
ID:	567597   Click image for larger version
ID:	567598   Click image for larger version
"DON'T BE A CV-1 HATER... IT JUST MAKES YOU LOOK STUPID"
  #63
Old 06-02-2021, 06:05 PM
pastry_chef's Avatar
Very nice! Can you share more?
bore and stroke?
RPM of peak power and torque?
valve sizes?
rocker ratios?
  #64
Old 06-02-2021, 07:00 PM
bore and stroke?
valve sizes?
rocker ratios?
4.155 bore
4.00 stroke
7300rpm HP peak
2.190/1.75
1.7/1.7 rockers
  #65
Old 06-02-2021, 07:04 PM
more pics ...
ID:	567600   Click image for larger version
Name:	Bill's Cell Phone Stuff 2013-2017 989.jpg
ID:	567601   Click image for larger version
Name:	Bill's Cell Phone Stuff 2013-2017 950.jpg
ID:	567602   Click image for larger version
ID:	567603   Click image for larger version
  #66
Old 06-02-2021, 10:14 PM
slowbird's Avatar
slowbird slowbird is offline
4.155 bore
4.00 stroke
7300rpm HP peak
2.190/1.75
1.7/1.7 rockers
How has it ran at track? Just curious how the stock block is holding up.
  #67
Old 06-03-2021, 03:20 AM
Dragncar Dragncar is offline
X 2
  #68
Old 06-03-2021, 07:04 AM
Stan Weiss's Avatar
4.155 bore
4.00 stroke
7300rpm HP peak
2.190/1.75
1.7/1.7 rockers
Hi Bill,
Is that a 290 cc intake port?
Thanks,
Stan
Pontiac Pump Gas List
  #69
Old 06-04-2021, 04:45 PM
... my car is still getting the suspension work and cage work done at the chassis shop, the engine only has dyno time so far ...
  #70
Old 06-04-2021, 04:48 PM
Originally Posted by Stan Weiss View Post
Hi Bill,
Thanks,
Stan
... yes, that top end was sold, it went 9.0's on a 535 single 4 set up in a 3300lb car, but broke the transmission, so hopefully the new trans will help some too ...
... my engine is getting an as cast CV-1.1 top end on it now ...
