Ign. box analog or digital
My old Mallory box was acting up today, Shopping for a new box. So many choices. A few recommend the MSD grid. I only need a start retard, rev control for launch, high speed rev control and one stage retard.
Any recommendations? |
I think I still have a Mallory pro mod ignition system I’ll let go for about $175 with coil
Hyfire 7c GTO George Last edited by GTOGEORGE; 05-22-2021 at 10:06 PM. |
Pic
GTO George |
I am not a hardcore racer, but have used the MSD 6al-2 programmable box. Just lock out the distributor and then setup the timing curve, rev control etc on the laptop. Power grid looks,like,the same thing but with way more adjustability and features.
6al-2 programmable probably would cover what you need, but the power grid gives you lots of room to grow. |
I went with a grid...nice features...
MSD 6530
I have had luck with the Mallory hyfire VII for close to 10 years. It started last summer cutting off, Have to kill power to the box before it will start again. I installed a fan blowing on it and it helped. Now it started acting up again in this 90 deg heat. I have it mounted inside on the firewall. They don't make it anymore.
I am look for something simple to adjust. Thinking of the old school MSD 7AL. |
I got a crane hi-7 with a dec9000 pretty simple but not like the Olden days....for sure! GTO George |
my go-to is the MSD Digital 6, easily meets your requirements. As long as you use quality wiring and connectors, it will give you zero problems from my experience.
I saw one guy going on about how much of a POS his box was, well, he had scotchlocks and such ... thats a bad data point instantly.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
X2 on the Digital 6.
to be honest the start retard has cost me more flex plates than I can remember---
Thread Tools | |
Display Modes | |
