6.98 @ 199mph 4.53 @ 164mph |
The Following User Says Thank You to wreckmastr For This Useful Post: | ||
I agree with that, to some extent...
Ed at Molnar seems to think his crank wont have a problem holding up... |
What power adder do you run?
I would without a doubt use a custom Carillo rod for your application. If you design the piston (billet) and rod properly you wont be much heavier than an aluminum rod set up. You will have a much longer life with the Carrillo rods and not have to worry about untorqing the rod bolts in the off season. Keep an eye on the rod bearings until you establish your tune up. After that they won't be an issue.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
I can see running a billet crank with that combo...
What kind of car do you run it in? |
All steel 69 GTO on radials. Nothing special.
Why didnt you say Sikgoat? LOL
Nothing special huh? Only the baddest 69 GTO on the planet. |
The Following 2 Users Say Thank You to opeliac For This Useful Post: | ||
Molnar.....Chinese crank, 2,500hp.....have fun! GTO George |
I’m not stressing the crankshaft in the least bit. The rods are really my main focus. |
The Following User Says Thank You to opeliac For This Useful Post: | ||
Now those are some heavy duty wrist pins.
Looks like pin buttons, or is that the actual thickness of the pins?
I've never slackened the rod bolts over winter in any of my ali rod engines - maybe if you live in the North Pole yeah. |
We ran the 1.094" wrist pins as well. Funny BME story. At the end of a season when we finally had the Boss Bird running well, I sent back 16 wrist pins to BME for inspection. They were H11 pins for Top alcohol engines. About a week later, I get a call from Bill himself. He says, "I got good news and bad news for you!". "The bad news is all 16 wrist pins are bent, some .005"-.006. The good news is your dumb little Pontiac is making enough power to bend my wrist pins!". He replaced them all with their Vasco-Jet top fuel pins at no charge. He said, "you guys won't bend these". He was right and they were 12 grams lighter than the H11 pins. BTW, why nitro engines bend wrist pins? It's all the timing lead they need to burn the fuel. Our engine ran best at 53-55 degrees lead. Lots of liquid fuel to vaporize and burn. Higher power nitro engines run about 70 degrees of lead. Tremendous force on those pins.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
If you read the instructions with the BME rods and most others they recommend it if you live in the cold climate States. I never have either and only had a few crack because of it.... According to the rod manufacturer.
#38
ps, my cars are always garaged and it doesn't get that cold over here even in Winter. (except for that one time I left the car in the trailer for a week and the block froze and cracked, but that's another story
#39
for what its worth I ran CROWER fully counterweighted billet crank never an issue.
#40
How many runs do you guys typically put on the rods before replacing them?
