Old 08-02-2022, 05:00 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default 61 Questions...
Is there an original dealer selling price list out there somewhere for all the 61 Pontiac models?
What year 5 lug brake drums interchange....59-64?
Also.....just checked on Rockauto...and no rear shocks are available.
Any other sources? Thanks
Old 08-02-2022, 05:43 PM
webfoot's Avatar
webfoot webfoot is offline
5 lug drums are the same 59-64, for some reason RA doesn't show them for a 62 but 64 also used the big 9.3 rear and it has them listed for them. (raybestos 2265R) They don't look exactly the same (new replacements are finned vs OE smooth) but they fit fine.
Same with shocks - though I'm not sure if the upper mount is the same between 62 and 64, so you'd need to confirm. I have some KYB gas-adjust shocks in there now but not sure if they won't be changed out by the time its on the road.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 08-03-2022, 04:25 PM
Thanks...for the info
Drums are currently out of stock....
The rear shock listings ...are hit and miss 59-64 should be the same I think...
I found a cheapie Monroe rear....that should work.....I will advise when I attempt installation..
Old 08-03-2022, 05:07 PM
Stuart's Avatar
Stuart Stuart is offline
I asked the same question about rear shocks back in December, here's that discussion: https://forums.maxperformanceinc.com...d.php?t=855458 Apparently the deal is the lower mounting stud is included with 1961 shocks but isn't included with 1962 shocks, so you have to press the stud out of your old shock and reuse it with the new one.
I have copy of John Gunnell's book '75 Years of Pontiac-Oakland' that was published in 1982 by Crestline. It has a limited amount of pricing info including base prices for some models as well as prices for a few options (for instance, base price for a Bonneville two door hardtop was $3,255, and 8 lug wheels were a $107.06 option.) If there's a specific model or option you're interested in, let me know and I'll check to see if it's included in the book.
Old 08-04-2022, 10:54 AM
pfilean's Avatar
pfilean pfilean is offline
The picture from the 61 manual in Stuart's post doesn't look like what I have on my 61 as to the lower mount. Probably the lower has already had the parts store replacement lower stud installed and had the "62" shocks installed. I didn't buy and install these shocks so I can't say for sure. But it would appear that with the replacement lower stud that 62 shocks should work. That tape is only in the picture from when I was considering adding a sway bar and wanted information.
Old 08-04-2022, 12:02 PM
Thanks for posting....I actually have a copy of that book that I bought...about 30 years ago......
I moved about 5 years ago......and the library is still a shambles........lots to unpack ...
I guess I'm "internet lazy".......but still love my car books/magazines..
I'd be happy knowing what the MSRP was on all four 61 Bonneville models.
Old 08-04-2022, 03:53 PM
Stuart's Avatar
From '75 Years of Pontiac-Oakland' by John Gunnell, 1982 Crestline Publishing:
1961 Bonneville station wagon $3,530
1961 Bonneville convertible $3,476
1961 Bonneville two door hardtop $3,255
1961 Bonneville four door hardtop $3,331
Some options:
Outside rear view mirror $5.54
8.00-14 whitewall tires $40.78
8.50-14 whitewall tires $62.00
Backup lamps $14.31
Bucket seats $116.21
Eight lug wheels $107.06
Dual exhaust $30.88
Tinted glass $43.00
Air conditioning $430
Hydramatic transmission (the Roto-Hydramatic in Catalina and Ventura) $231.00
Power brakes $43.00
Custom wheel covers $31.00
Two tone paint $12.80
Power steering $107.50
Guidematic headlight control $43.00
Circle-Aire heating $94.135
Direct-Aire heating $75.32
Safe-T-Track differential $42.50
Windshield washer $13.02
Electric antenna $30.88
Ash tray lamps $4.25
Underhood utility light $7.10
Power seat $96.84
Electric tailgate window station wagons $31.85
Station wagon roof luggage rack $98.56
Old 08-04-2022, 04:14 PM
Awesome...
Thanks for taking the time to post...
Old 08-04-2022, 11:39 PM
You can buy universal shock mounting stud packages new that work just fine. I used them on my 1962.
Old 08-06-2022, 12:27 PM
Just wondering what the purpose/significance is....of this upper bumper bolt?
On my car it appears to be cosmetic....there doesn't seem to be a bracket behind it...
Old 08-06-2022, 03:38 PM
Stuart's Avatar
I've always wondered the same thing. There's no mounting bracket there, or provisions for some sort of optional guard or anything. I believe originally there was a snap in plug that went there, rather than an actual bolt.
Old 08-06-2022, 06:17 PM
Ok...thanks for the info....
'nother question for you.....
I want to install this gas door guard....and when I removed it from the parts car....it had 2 bumper bushings...with screw holes in it..
I need new ones and the replacement ones I see are just push-ins...
Any clues on where I can find correct ones?
Am going to invade the local True Value fastener isle....next week..
ID:	595896   Click image for larger version
Old 08-06-2022, 08:44 PM
Stuart's Avatar
Don't know of anywhere that has those specific rubbers but you could check Steele Rubber or Metro Molded Parts to see if they have anything universal that's close enough. Another potential source is https://www.clipsandfasteners.com
Old 08-07-2022, 10:16 AM
pfilean's Avatar
Those pseudo bolts were used a number of times for years. The 61 has one on each side on the front as well. If I remember correctly Chev 49-52 had one at the center of the bumper. They got an unthreaded bolt that was held in with a spring clip "nut".
Old 08-07-2022, 11:05 AM
misterp266's Avatar
Default Fuel door
Here’s some Ford bumpers that are close.
https://www.ebay.com/itm/29412549638...AAAOSwzV5geZDd
" Darksiders Rule "
Old 08-07-2022, 01:11 PM
Good call....Time to find a junkyard...
Old 08-08-2022, 04:52 PM
Ok...I've ordered the Brand X bumpers......
I will change out the torx screws...for some pan head phillips...and nobody will be the wiser..
Does anybody know the bulb #'s....for the dome/map reading lamp?
Thought they might be in the owners manual...but didn't see them there
Old 08-08-2022, 05:19 PM
webfoot's Avatar
Philips says 1004B2, and also references a 90 - do a google search and make sure it looks right.
This is a good tool, or in rock auto "electrical - bulb & socket"
https://www.rockauto.com/en/catalog/...-bulb+&+socket
-Jeremy
Old 08-08-2022, 08:54 PM
Thanks for posting.....I'm a big Rockauto fan...but never thought to check for light bulb listings..
Old 08-09-2022, 10:40 AM
pfilean's Avatar
1961 Shop Manual page 11-81 Lamp Usage. Has them all. Dome bulb 1004. And then I would be tempted to find the LED equivalent.
Thread Tools
Display Modes
