Old 10-04-2022, 09:38 AM
Mike S's Avatar
Mike S Mike S is offline
Default No top end mph
I took the 1050 Holley and restrictor plate off and replaced with an 850 Holley. I lost finish line mph. 60;s are 1.33 with an 1/8 of 6.30/107 but only manage 9.9 barely breaking 132mph . Do you think it's the carb being small or should I look at a gear change? Car never had high mph even with the 1050.
I have a 4.10 gear and 30" tire. Shift at 6400 and cross the line at 6800.
I run a 10.00 index and am tired of having the lowest mph. I am always looking behind me to see where they are. Would like to be around 135mph.
Only ran it all out thru the 1/8 once with the 1050 and ran a 6.04/111 with a 1.29 60'. Didn't have enough gear to run it thru the 1/4.
Old 10-04-2022, 10:58 AM
Stan Weiss's Avatar
Do you have data logging? To me It looks like to much convertor slippage.
Stan
Pontiac Pump Gas List
Old 10-04-2022, 11:32 AM
Mike S's Avatar
No data logging. Calculator shows just about 9 percent slippage. Afraid if i put a 3.90 or 3.73 slippage will go higher,
I have an ATI MRT 8" converter stall right at 5000. I leave at 3800 with a trans brake.
Old 10-04-2022, 11:42 AM
25stevem's Avatar
25stevem 25stevem is offline
You should have not done that type of testing without having a vacuum gauge hooked up to view in front of you when making a pass.
Having such would have clearly shown if the Carb is too small.
With any flat out race motor if your approaching your shift point and the gauge is reading 3/4" of Hg or over then your Carb is too small.
I do stuff for reasons.
Old 10-04-2022, 12:22 PM
Stan Weiss's Avatar
OK. I did a quick calculation and I came up with between 10% and 11%
I have always run a manual trans. So I can only go by what some others have told me. Using your car as an example they went to a 4.33:1 saw an increase in MPH and no increase in RPM. Maybe give ATI a call and see what they think
Stan
Old 10-04-2022, 02:20 PM
Mike S's Avatar
The reason for the carb change was to get rid of the restrictor plate. I had a 1050 with a 1.550 restrictor plate under it. The 850 throttle plates are 1.75 and have no restrictor plate. I notice with the 850 60's and 1/8 mile is better and more consistent than the 1050 with the small restrictor plate.
Last time out 1/8 mile times varied .004 over 5 runs. I used 1/8 mile because of hitting the brakes in eliminations.
Figured it can't have any more vacuum than the 1050 with the restrictor plate at wide open.
Old 10-04-2022, 03:58 PM
Region Warrior's Avatar
Tire size? Just a thought...
Old 10-05-2022, 12:40 AM
Dragncar Dragncar is online now
My 850 has 180 throttle plates. Are you sure you have a 850 ?
4150 carbs are always going to react better. More consistent 60 foot times over a 4500 carb. The way to go for bracket racing.
Old 10-05-2022, 09:37 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
4150 850(1000HPs) have 1.75 throttle blades.
Skip Fix
Old 10-05-2022, 10:32 AM
I think the blades are stamped 180 but are 1.75" diameter?
(been over 25 years since I looked at one)
Old 10-05-2022, 01:44 PM
cgeise's Avatar
cgeise cgeise is offline
have you had it on a dyno to find out where max power is being made -- what rpm.??
Old 10-05-2022, 03:32 PM
Yup, I just went out and measured a HP 1000 and they are 1.75 dia with a 180 stamped on them.
I just remembered drilling a 1/8" hole right through the "8" back in the day.
Wonder why they do not have the actual diameter stamped on them ? Has to be some reason.
Old 10-05-2022, 03:51 PM
I think they are a part number or ID number.
Seems like the 750/800 had maybe 179 stamped number?
(still been a long time since I saw mine)
Old 10-05-2022, 04:01 PM
Mike S's Avatar
Never had it on a dyno. Been about 8 years with the same combo. Tried different shift points and likes 6400,. I notice the smallest head wind slows the car down, Not being the most aerodynamic body style. The 2 times I took it out had some low wind, I think this might be some of my problem since I installed the 850.
It did mph a little better when I was running a 30" slick. I switched to a 30" radial 2 years ago. The radials hook a lot better and are more consistent. Not knocking slicks, just radials work better with my car. Stock suspension and 3400lbs.
Old 10-05-2022, 06:54 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
Mph is horsepower.
Mph is down, hp is down.
Going from a 1050 to 850 will slow you down. It may be more consistent, but you will slow down.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 10-06-2022, 12:43 PM
cgeise's Avatar
To many unknowns here-- as in head flow , engine size ect.ect. I suspect the 6800 rpm finish line is well past peak HP. just a thought.
