Old 12-28-2021, 09:30 AM
Stan Weiss's Avatar
In a way, yes. He needs to do more than one thing to get that thing to 60'. Say does does it and gets 1.40 60 foots, doable. I can get 1.42-1.43 out of a POS 9-1 iron headed TRW junk heap with a 850 DP, and he has a 11.3-1CR High Port with 1050 with better intake. He should be making 100 more HP than I do with about 200lbs more weight.
It takes 647HP to get 3800lbs to 10.50 and 607 HP to get to 127 mph.
If you go from a 1.56 60' down to a 1.40 60' I would say 3-4 mph, maybe 5 mph. You have to get that weight moving so the engine can have a chance at crossing the line 200RPM past peak HP.
IMO the biggest difference would be a real converter, 1200$ worth. But then again it would not be very streetable.
No free lunches. More cubes and tq and he would have a shot at low 10s pump gas power with his setup.
Not the way I have seen it happen at the track.
No the way my computer simulation works.
60 Foot ET = 1.4351
330 Foot ET = 4.1987
1/8 Mile ET = 6.5900
1/8 Mile MPH = 102.0106
1000 Foot ET = 8.6826
1/4 Mile ET = 10.4611
1/4 Mile MPH = 127.0824
Stan
Pontiac Pump Gas List
  #82
Old 12-28-2021, 02:38 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Smile
I asked you about that engine awhile back and you did not respond.
Is that a 750 HP true pump gas 461 stroker ? If it is that would make you top dog. I do not know of any higher.
Lets see the dyno sheet, please.
Not going to do a thread about the engine. Don't need a certain team critiqing my build, claiming I'm being dishonest and have a happy dyno just because my chit out performs theirs. Heck once they started using the same parts I do they picked up an instant sixty horsepower or so but still can't put two and two together.
I'd PM you a sheet but you have proven to be not trustworthy with private pictures.
I have no idea if it's a "top dog" but the customer was ecstatic with the results and that is all that matters over here.
Go fast, see Elvis!
  #83
Old 12-29-2021, 12:40 AM
slowbird's Avatar
slowbird slowbird is offline
60 Foot ET = 1.4351
Stan
Ya I haven't seen it work that way either. Unless a lot of power is found the causes the 60ft to drop then mph will probably go up a good amount them. But just working converter, chassis and gearing to get 60ft down isn't going to lead to any real gains in mph usually.
  #84
Old 12-29-2021, 01:18 AM
Dragncar Dragncar is offline
Well, you mentioned it trying to disprove me. I think if you use it as a example putting it up would be the thing to do. I am quite certain a 461 with HPs could put up 750 HP with .650 cam. but pump gas too would be a feat. You should be proud of it. What was the static CR, could you at least answer that ?
Not sure where you are going with anything about pictures. I have never posted any you have gave me.
BTW, who is "they" ?
  #85
Old 12-29-2021, 01:21 AM
If your engine is not done before the strip, why wouldn't it gain some MPH ?
My heap always gains a MPH or two with a good 60 foot. And it is done well before the stripe.
  #86
Old 12-29-2021, 11:57 AM
Stan Weiss's Avatar
These are from what was my every day driver. 2000 Mustang GT 5 speed. These are from different days. This is all I have on this computer. When get some time I will look for examples from the same day at the track (ATCO)
Stan
ID:	580895   Click image for larger version
  #87
Old 12-29-2021, 08:11 PM
PAUL K's Avatar
I doubt your going to see much MPH difference with varying 60 ft times. I've always thought the MPH was related to the horsepower the car was making. I remember this theory put to the test in a magazine from the sixties. They ran a car (which I think may have been a 421 Catalina) from a dead stop in the quarter mile and then rolling through the starting line from a ten mph roll and the ET changed but the MPH was the same.
I posted two slips from my car on the same day and the better 60 ft actually had slightly less MPH.
I remember Jim Hand talking about this and he said his car would MPH better with the slower 60ft because it had more time to accelerate..... From what I remember, that was discussed many years ago.
Go fast, see Elvis!
  #88
Old 12-29-2021, 11:55 PM
Stan Weiss's Avatar
Paul,
That is interesting. I can enter roll into my software but almost always use the default 11.75 inches. Which is what I used for the above simulation (post #81).
When I change the rollout to 60 inches. I get.
60 Foot ET = 1.2498
330 Foot ET = 3.9877
1/8 Mile ET = 6.3727
1/8 Mile MPH = 102.2137
1000 Foot ET = 8.4621
1/4 Mile ET = 10.2389
1/4 Mile MPH = 127.1941
When I change the rollout to 120 inches. I get.
60 Foot ET = 1.1353
330 Foot ET = 3.8432
1/8 Mile ET = 6.2205
1/8 Mile MPH = 102.4625
1000 Foot ET = 8.3060
1/4 Mile ET = 10.0805
1/4 Mile MPH = 127.3312
In neither case has the engine hit the REV LIMITER.
Stan
