Old 11-19-2023, 06:01 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Default Flywheel and clutch questions
I have a 76 400 that has come out of a car with an automatic. Currently it has a 166 tooth flex plate with matching starter. Register on crank is 2.49" I am using the original manual Muncie M13 3 speed from my 71 GT-37.
I need to find a flywheel and clutch that will work. I know I need a flywheel with a hole for the 2.49" register, but a couple questions:
1) To use the starter currently on the engine do I need to use a 166 tooth flywheel? (Maybe a flywheel for a 76 6.6 Lemans of Firebird?)
2) For the clutch do I shop for a clutch for a 71 Lemans/GTO?
Old 11-19-2023, 06:31 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Flywheel for all late model Pontiacs have the same tooth count and use the same starter, although I will qualify the starter. on my 81 Turbo 301 was different.
Clutch- you need to get the flywheel first to see what size clutch it will take. Some aftermarket flywheels are drilled for 10.5 and 11".
Skip Fix
Old 11-19-2023, 07:16 PM
tom s tom s is offline
I think the new aftermarket flywheels come with a ring so it can be used on both size registers.Tom
Old 11-20-2023, 09:16 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Make sure you dial in the bell housing with a dial indicator for center and parallel to engine block.
Old 11-21-2023, 11:57 AM
79 Phoenix's Avatar
Would a 76 crank be considered "late model"? Here's a flywheel I'm considering but need to see if it's drilled for 10.5 or 11" clutch or both.
https://www.ebay.com/itm/15529815683...3ABFBMvpmYqf5i
Old 11-21-2023, 11:59 AM
79 Phoenix's Avatar
I've heard there are some like that but haven't seen any.
Old 11-21-2023, 12:02 PM
79 Phoenix's Avatar
Someone loaned me a dial indicator but I need to figure out how to use it. Hopefully there is a youtube vide on how to do this.
Old 11-21-2023, 12:26 PM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
That looks like its for a Chevy not Pontiac V8.
Old 11-21-2023, 01:06 PM
McLeod makes a good steel wheel for our cars.Tom
Old 11-21-2023, 08:18 PM
MatthewKlein MatthewKlein is offline
I used this flywheel. 166 tooth. Drilled for 10.5 or 11" clutch. Compatible with 2.5 or 2.75 crank flange. Has a removable counterweight for 455 engines.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-21-2023, 10:33 PM
74Grandville 74Grandville is offline
where are you located? i have a stock one from a 78 TA. 11" clutch.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 11-21-2023, 11:13 PM
79 Phoenix's Avatar
Listings show it is 2.5" and for 76-77 6.6L Pontiac...
Old 11-21-2023, 11:14 PM
79 Phoenix's Avatar
I'm in Ephrata, PA 17522
Old 11-22-2023, 12:08 PM
Skip Fix's Avatar
On the PRW the removable weight is for either any motor size that is factory balanced and not completely internal neutral balance. Look at a factory flexplate and you can see there is a hole missing for "external balance".
Skip Fix
