Old 04-05-2021, 11:28 AM
Default Where do you put your #1 wire on your distributor?
I know that any location will do to put the #1 spark plug wire, while the engine is TDC #1 compression stroke. But I just think that mine is not where I want it. The engine runs great, but the number one plug wire is in the 7:00 position, if 12:00 is the firewall and 6:00 is towards the front of the engine. I thought that it would be closer to the drivers side. We’re switching over to an HEI soon so I can put it in the factory location at that time.
Old 04-05-2021, 11:39 AM
78w72 78w72 is offline
1:00, or the terminal next to 12:00
Old 04-05-2021, 11:52 AM
Sirrotica's Avatar
Here's a diagram so you can see it:
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 2 Users Say Thank You to Sirrotica For This Useful Post:
Old 04-05-2021, 11:54 AM
Ok that is super helpful. Thanks.
Old 04-05-2021, 12:00 PM
Sirrotica's Avatar
My pleasure........
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-05-2021, 02:51 PM
Jim Moshier's Avatar
1:00, or the terminal next to 12:00 is the same as mine.
Jim Moshier
1962 Catalina 389
Old 04-05-2021, 03:07 PM
LOL I love how it has a notation that the 307 "Pontiac" engine rotates clockwise. In other words it's the Chevrolet 307 that Pontiac used in 71 X-bodies.
https://youtu.be/XqEydRRRwqE
Old 04-05-2021, 03:12 PM
Sirrotica's Avatar
Not to mention the 350 and 305 corporate engines that they left out.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-05-2021, 03:13 PM
Bill Hanlon's Avatar
... and 72. I had one.
Old 04-05-2021, 06:06 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default #1 post
Yes the pc in sirroticas post is how mine is landed. took a few tries but was good.
helped with routing wires.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
Old 04-05-2021, 06:15 PM
sdbob sdbob is offline
I tried different clockings over the years ,trying for convenience. Now I have mine like Sirroticas pic.
Old 04-05-2021, 08:16 PM
ta man ta man is offline
Just installed a 350 Pontiac with the distributor installed from the previous owner. I double checked TDC and number one was directly across in the normal 6 spot..guess they must have stabbed it in but didn't confirm TDC..Or they didn't care..I get too anal and need it in the factory spot.
The Following User Says Thank You to ta man For This Useful Post:
Old 04-05-2021, 08:35 PM
Sirrotica's Avatar
They probably had it 180 off, and installed it on exhaust stroke instead of compression. When you try to just re arrange the wires to compensate, nothing fits like it should, then the next guy has to figure out WTF the wires are all mixed up.
Agree it's better to set it up like the factory did.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-05-2021, 09:06 PM
4dblnkldude's Avatar
Interesting thread, I do the 5:00 position.
Old 04-05-2021, 10:16 PM
That's what I figured too..they did number all their wires so they seem to fit ok.
I won't mess with this car it's ok. On my higher horsepower car I'm much more fussy.
What I like is when it's on the proper post you can keep the number 5 wire and the number 7 wire isolated from each other a little easier.
