speedometer seal
For the life of me, I can't remember whether the open side of the small seal that goes around the speedometer driven gear (TH400) faces in (towards the transmission) or out (toward the retaining ring/speedometer cable).
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea Last edited by Gator67; 02-01-2021 at 09:34 PM. |
That is the flimsy seal. open side faces inward. I think. Going from memory.
Should be a c-wire clip that pushes against the seal, kinda locks the seal in place. |
Yeah I was thinking that since it’s a lip seal, the lip should be on the oil side. But in the back of my mind I remember needing to do something counterintuitive when I replaced the last one years ago. Someone must know for sure.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
The Following User Says Thank You to Gator67 For This Useful Post: | ||
Lip seals that retain fluid always have the lip face the fluid. Seals that are meant to keep dirt out always have the lip face the dirt/contamination. In this case, you're keeping fluid in. The lip goes in.
The Following User Says Thank You to tempest1964 For This Useful Post: | ||
