59 Mickey Thompson heads n parts
Figures, he won't sell the FI separately, been looking for a Pontiac Hilborn 8 stack style setup for one of my projects. Haven't had any success at all.
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
Have owned at least 3 sets of those heads.Originally 1.80 and 1.60 valves.low performance head with 55-60 water pattern.Good luck with anything close to that.The complete alu M/T engine I bought was less than that.Tom
have owned |
Still has stud oiling for rocker arms!
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
The last set I did,Dave put screwin studs and we oiled thru the rockers.Also ported them to 220.Tom
pretty sure that Hilborn is 55-60 water also.Tom
Posted pictures of these heads and injection years ago. Don't remember what thread?
DragStarLeMans |
When with Tyree in the 60s he used the Olds.Pretty common back then.Tom
Were there other aluminum D port Pontiac heads available?
Back in 1989 or so, I was at Bremerton Dragway and there was a guy walking round with an aluminum D port Pontiac head. I don’t remember much about it, other than he had one.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
there was another version with both intake and exhaust on the same side of the heads.Tom
I believe the single head he had was a conventional D port, the only difference was it was aluminum. So I’m guessing it was a rare item.
The Algon Pontiac Fuel Injection parts are worth that kind of cash.
The Hilborn stuff for sure is not, in my opinion. Tom V.
Scott, Thelander, Mark wanted to say thank you for posting this link here. I talked with him for over an hour today. Great guy and the story is the same about the heads. When will you get a chance for parts like this??? Wish I was working.
DragStarLeMans |
I had a Pontiac Hilborn , small butterfly hurt airflow.
It was likely these heads. They have been around Washington for a while, changed hands a few times.
DragStarLeMans |
