Old 05-01-2021, 12:05 PM
Default Bilsteins
I'm considering putting Bilsteins on the '67 LeMans. I've heard more positive than negative reviews on them, and their own site says that they work well with factory springs. We'll be replacing the springs as well of course, since they are original and worn out.
I was on their site and found the front shocks no problem. But they don't show rears for a '67 Pontiac A-body. I found this strange. Why wouldn't they have a complimenting shock for the rear. So I do what I always do, which is to input a Chevelle into the search box. Sure enough, there they are for a '67 Chevelle. I wasn't aware that there would be a difference between the Pontiac and Chevy rear ends. Is there a difference that would prevent me from using the rear ones spec'd for a Chevelle, or is this just an oversight on their part?
Old 05-01-2021, 04:29 PM
nashcar nashcar is offline
Same issue with my 67 Nova. Finally found Fox shocks for the front.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 05-01-2021, 04:45 PM
shermanator2 shermanator2 is offline
Have you tried calling Bilstein of America? I have not talked to them in a few years, but they used to be quite responsive and could even make custom stuff.
Old 05-01-2021, 05:53 PM
I actually called them and they had no plans to make shocks for the front of a 67 Nova.
69 Z 302 M21 3.73
69 FB 400
Old 05-01-2021, 06:59 PM
Konis work well.
Old 05-01-2021, 08:14 PM
Wow, in shopping around for the KONI's, it appears that they cost more than the Bilsteins.
Old 05-01-2021, 09:27 PM
gtorich gtorich is offline
Hey 66 sprint..........have bilsteins on my 66 Gto.......front 24-029728 # under that F4-BE3-2972- H 1
Rears are 24-009294 Hope that helps
Rich
Old 05-01-2021, 09:36 PM
gtospieg gtospieg is offline
I did call Bilstein and asked them about rear shocks for 67 GTO. They had no listing and gave no helpful info.
Gtorich...how did you come up with the part # for the rears? Thanks
Old 05-01-2021, 10:38 PM
Now that is a good question.............ive had them on the car for about 10 some years.........i really have crs...........im thinking i got that info from Bart on the forum.........sorry for not being much help.
I know they are on summit racing, seems to stop at 68 or so.............otherwise no problems with them on my 66.
Rich
Old 05-01-2021, 10:56 PM
Ok, did a search, had some things screwed up, i had the old # for bilsteins AK 2080, they said the 24-00924 would work, think Bart chimed in my post from April 22 2019, this is when i was looking for a replacement of the AK 2080 rear shocks from bilstein.
Kind of a pita, but got them in ok......Believe the post title was Bilstein AK2080........hope this clears up some of the confusion.
Rich
Old 05-01-2021, 11:12 PM
https://www.ebay.com/itm/40047383712...8AAMXQ01dRepZd
Seen this on ebay, 2 AK 2080
Old 05-02-2021, 01:25 AM
I bought these Bilsteins for my ‘64 Tempest about 12 years ago. The same ones will fit your ‘67, hopefully they’re still available.
Old 05-02-2021, 08:54 AM
That's all super helpful. I believe that for whatever reason, Bilstein didn't create a listing for a '67 Pontiac A-body and maybe they don't feel like creating one. But they are available so I'll grab them.
Old 05-03-2021, 07:06 AM
66sprint6...Where are you getting them? Part #s? Thanks.
Old 05-03-2021, 09:42 AM
I went directly to Bilstein for the part numbers. Then I just googled to get the best price. As it turns out, I can buy them directly from Bilstein in Canada. In the US, you have to buy from a retailer.
Here’s the current part numbers.
https://cart.bilsteinus.com/details?...51489&Pos=Rear
https://cart.bilsteinus.com/details?...1489&Pos=Front
Hope that helps. I’ve seen them listed on EBay with the old part numbers as well (AK2020, etc).
Old 05-03-2021, 09:44 AM
Formula8's Avatar
Formula8 Formula8 is offline
Koni's are adjustable, Bilsteins are not. That doesn't mean the Konis are necessarily better but may offer increased flexibility if needed. With increased functionality, usually comes increased cost. My car has Koni but I put in a set of Bilsteins in a friend's C3 Vette and they were balanced perfectly for that car. Either shock is going to be a solid choice.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 05-03-2021, 11:59 AM
ZeGermanHam's Avatar
Yeah, you can't go wrong with Bilstein or Koni. They're both high quality. Interestingly, I noticed that UMI Performance now supplies Bilstein shocks with their complete suspension packages rather than their own in-house UMI shocks that they used to include until very recently. They don't list the actual part numbers on their website, but I bet they'd provide that info if you contacted them.
1998 BMW 328is (track rat)
Old 05-04-2021, 11:20 AM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
Thanks for this. I’m running KYB’s and have been looking to upgrade.
Have you ordered them yet? Curious on fitment and ride quality.
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
Old 05-05-2021, 11:57 AM
I haven’t ordered yet, but I intend to shortly. I’ll definitely post a review after installing them.
Old 05-05-2021, 08:51 PM
mrennie's Avatar
mrennie mrennie is offline
FYI, I checked prices on Bilstein Canada's site for front and rear shocks for my 70 GTO and even with the current 10% discount, Amazon Canada was cheaper and Summit Racing (with free Fedex shipping) was still lower than both.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Thread Tools
Display Modes
