Felpro Gasket Set
I am looking on the Felpro website and I see the following full gasket sets listed for Pontiac
HS8518PT 8518PT FS8518PT KS2616 260-1025 Does anyone know what is the difference between these sets and which one would you recommend? This is for a high performance street machine with iron heads. Thanks
Tim Corcoran |
HS is Head Set
FS is Full Set PT has something to do with the composition of the gasket material
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
I have bought 2 full gasket kits from Summit. One is a standard build kit, the other is the performance version. The performance version has the better 1016 head gaskets and RA IV intake gaskets with the blue strips on one side. There may be other differences that I did not pay attention to.
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
FelPro PermaTorque head gaskets
PT stands for PermaTorque - when they introduced this line of head gaskets (many, many moons ago), they advertised that they did not need to be re-torqued after the first heat cycle. We've always re-torqued them anyway...... |
The KS is the same as a FS set, but come in a plain box, engine builders use them, they are usually cheaper, and don’t contain all the extra gaskets that you don’t need. The 260 set is the same as the KS set, but that is a Sealed Power number, still same Fel Pro stuff. The am thing to make sure of, is that the set you select has the correct intake gaskets, the heat riser holes are different depending on year.
Thanks for the great responses that is what I was looking for. Does anyone know what the compressed thickness is of the Felpro 8518PT head gasket?
Tim Corcoran |
According to the catalog .0415
The Felpro 2806 is the High Performance full gasket set, which includes the .039" compressed thickness High Performance 1016 Head gaskets and the Printoseal 1233 RAIV sized Intake Gaskets.
The 8518PT head gaskets are said by some to measure around .043-.045" compressed thickness, and do not have the pre-flattened steel wire ring around the bore like the 1016 does.
1978 Trans Am Pump Gas 461 Stroker |
the 260-1025 is USUALLY the cheapest set, has the 8518 head gaskets.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
