Old 06-09-2021, 07:21 PM
padgett's Avatar
padgett padgett is offline
Default Most cost efficient tranny.
3000 rpm at 65 with the 3.55 is a bit much. Keep thinking about something with a long OD to get down to 2000 at 70mph.
Last time I looked wound up with a BW T5 speed that is only good for about 300 lb-ft and not 500.
Seem to be a lot of choices now in 5 or 6 speeds but what is the easiest (1st), most cost effective (2nd) manual OD trans to replace an M20 Muncie & how to identify ?
Appreciate some advice before I start looking. Is a grand or a grand and a half ballpark ?
Web Site
Old 06-09-2021, 07:44 PM
tom s tom s is offline
If your not going to beat on it a 3.42 first gear ST-10 and a tall real gear like a 3.08 would be good.I have one in my 62 GP with a 421HO engine and 2.68s in the back.LOVE it!Tom
Old 06-09-2021, 08:05 PM
padgett's Avatar
Thank you but I have a correct 3.55 four pinion in it now. Besides I likes lotsa gears (and lotsa carbs) so wondering:
Are 5 or 6 speed manuals plentiful now ?
Will one just replace my M20 Muncie ?
What does a nice one (does not need to be new, just good) go for these days ?
Web Site
Old 06-09-2021, 08:21 PM
pontiacmark's Avatar
pontiacmark pontiacmark is offline
The new Tremec TKX from Silver Sport Transmissions is worth looking into. The case should fit without modifying your floor pan. Realistically, it is about $5k all in. Depends on what you can reuse from the Muncie install.
1970 GTO 400 Atoll Blue, PS, PDB, A/C
Was M20 4 speed, now has Keisler RS600 5 speed.
The Following User Says Thank You to pontiacmark For This Useful Post:
Old 06-09-2021, 08:22 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Probably not the most cost efficient, but the best option out there right now looks like the Tremec TKX.
I have a T56, and while I like it...you have to cut the trans tunnel, build a custom cross member etc. etc. From what I have seen, this is not necessary with the TKX.
What Pontiacmark said above.....
The Following User Says Thank You to ID67goat For This Useful Post:
Old 06-09-2021, 08:24 PM
Your budget will hold you back from a 5 speed im afraid.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 06-09-2021, 08:33 PM
padgett's Avatar
Maybeso. Not that important since doubt will make any long road trips. Just a "nice".
Web Site
