Old 07-11-2002, 11:43 AM
beerwolf66tc beerwolf66tc is offline
Need a little help here, folks:
On my 66 Tempest, the wiper arms will not return to the bottom of the windshield when the switch is turned off (two-speed motor w/washer pump).
My question is: Is there anything I should look for before I go ahead and spring for a new motor?
"The road goes on forever, and the party never ends." - Robert Earl Keen
66 Tempest 389 (Sold but not forgotten)
73 Cutlass S
73 Cutlass S
Old 07-11-2002, 02:15 PM
george kujanski's Avatar
Check your email.
Regards, George
Old 07-11-2002, 03:14 PM
Thanks!
73 Cutlass S
Old 07-12-2002, 02:34 AM
vidguy's Avatar
vidguy vidguy is offline
OK you guys.... NOT FAIR... Share it here.... I have the same problem and always have. I turn off my wipers and they stop where they are..How do you fix it???
Thanks,
I'm just back froma vacation and trip to Las Vegas and The Grand Canyon. Passed too many desert junkyards that my wife wouldnt let me stop at..... arghhhh.....
Las Vegas,,, ahh yes helped me get my secret bank account closer to affording that Tri-Power!!!!!!
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 07-12-2002, 10:31 AM
I sent beerwolf the pages from the manual to help him diagnose the problem. Check your email; I sent you the same stuff. Hope it helps...
Anyone else?
Regards, George
[ July 12, 2002, 10:32 AM: Message edited by: george kujanski ]
Old 07-12-2002, 10:58 PM
Cardo's Avatar
Cardo Cardo is offline
I had the same problem.... took apart motor and found that shunt had burnt up. Had to spring for new motor, and took care of it. Make sure wires are on correctly, found previous owner had conectors turned around and forced on. Reguards
"I know just enough to keep me here, but not enough to get me out"
Old 07-12-2002, 11:02 PM
Cardo's Avatar
I had the same problem and disassembled the motor and determined that the shunt had burnt up. Pony up for a new motor. Mine had been mis-wired... previous owner had forced the connector on the wrong way. Reguards.
Old 07-13-2002, 10:37 AM
vidguy's Avatar
Yes, I got it. Thanks for sharing. In a nutshell.... Do I need a new motor? Damn I just took that one out and detailed the heck out of it as part of my "quick disk brake upgrade" that took all winter, and ended up including a new exhaust........ :-)
thanks!!!!!!
James
Work
Details here:
