Old 06-23-2005, 03:18 PM
esahlin esahlin is offline
I've designed/built the mold for a carbon fibre pontiac tunnel ram. Full carbon fibre (Cloth Fabric is 2x2 Twill 6K 10.9 oz) construction with 1/2" x 3" aluminum head-to-intake interface plates. Ive built one prototype from the molds and total intake weight turned out to be 9 lbs. (no water crossover...lol). I was surprised at how strong it turned out with only a few layers of carbon fiber cloth.....much stronger than I imagined.
The particular prototype ive built has been designed around one of my particular engines 462, Dports (2.3125 x 1.25 inlet 275 cfm).....plenum volume, runner length (to some extent), runner volume and runner taper angle are all designed according to my engine combo and the specifics of my head ports. The nice thing about the carbon fiber construction is that its possible to easily make all the runners exactly the same shape, size and taper....no casting flash. I'm working on a few other runner molds for different runner designs to accomodate my upgrade to some higher flowing e-heads (330 +) and much larger cam. Also, have a new runner/plenum design for the 350 I'm currently putting together. Its nice that the plenum size is adjustable with "stuffers" and or carb spacers. I would have liked to incorporate longer runners, but time and packaging (hood height) were limiting factors.
Theres nothing like a nice straight shot from the plenum to the intake valve. Starting, out with a couple of modified Holley 600 DPs that flow 700. Will see how well these things act on the street.
Was alot of work but also alot of fun....nice to have the ability to make a custom intake to suit my particular combo for the cost of materials...with no foundry/casting help needed. I'll try to get some pictures posted of my proto....it needs 1 more layer of carbon fiber too be cosmetically appealing.
Old 06-23-2005, 03:45 PM
Cool!
Can't wait to see the pics.
Old 06-23-2005, 04:34 PM
A picture
Old 06-23-2005, 04:41 PM
One picture
Old 06-23-2005, 04:45 PM
Ron Landis's Avatar
SAWWEEET!!!! Looks remenicent of the old "Rat Roaster"...remember?
Old 06-23-2005, 04:46 PM
A bit more sanding to do in these runners
Old 06-23-2005, 04:49 PM
Top....needs cosmetic work...will be done in a week or two.
Old 06-23-2005, 05:25 PM
Silver Judge's Avatar
Very impressive !
Nice work Esahlin
501 HP, 554 ft lbs TQ
Old 06-23-2005, 06:00 PM
On Vacation
Nice.
Larry at Brandywine did one of these 10+ years ago.
Let's see some numbers vs. what's currently available.
Old 06-23-2005, 07:20 PM
Saw a fella op the turbomustangs boards making carbon fiber body panels for his mustang...he made a roof panel first, I think he said it weighed 4 lbs after completion I would liketo know how to make carbo fiber stuff...where do you start out with so far as the molds go?
Mike
Old 06-23-2005, 07:23 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Looks remenicent of the old "Rat Roaster"...remember? </div></BLOCKQUOTE>
Jegstek....I havent seen it? Do you have a pic?
Old 06-23-2005, 07:32 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Larry at Brandywine did one of these 10+ years ago.
Let's see some numbers vs. what's currently available </div></BLOCKQUOTE>
Blown Nitro- Ive been out of the loop for a while so I dont think I know who Brandywine is...gotta link or picture?
Numbers? THe only other intakes I have are an RPM, Performer and a few irons laying around....anyone in WA want to donate their car/intakes for some testing, lol.
Old 06-23-2005, 09:55 PM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
1-610-793-1184 Larry Woodward call early in the day....They do killer work.
Old 06-23-2005, 10:45 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Congratulations, regardless of numbers; love to see the do-it-yourself approach!
Old 06-24-2005, 12:09 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">where do you start out with so far as the molds go?
Mike </div></BLOCKQUOTE>
Louisiana-
THere are so many different techniques to build the molds I couldnt describe them. There has been alot of advancement in carbon fiber part manufacturing...so now it is much easier to get very cosmetically appealing parts quickly (a process like vacuum bagging works awesome). If your looking to do parts like the guy doing body panels thats going to pretty involved....The molds are probably made the same way they make molds for Fiberglass panels...lots of molds for panels and such are made out of fiberglass then coated with wax and silicone to release the part when its cured. If you do a net search you will find some sites that talk about carbon fiber/fiberglass molding process and they also have a list of books/information etc. I used a high temp chemical resistant aerospace epoxy resin that was very difficult to work with.....very very sticky and it was super difficult to get a layup that would be beautiful enough for a hood or body panel. If you are looking to do smaller components like flat accesory brackets (I will be doing some in the future) etc or flat pieces....now those would be quite easy and definitely something one could easily handle in the garage and produce with some beauty.
Old 06-24-2005, 07:29 AM
Half-Inch Stud's Avatar
2 Brandywine Cyl (West Chester, PA) fellas brought their sheel-metal & sheet-aluminum Pontiac manifolds to me @ my parent's house in 1988. These manifolds looks similar to the Wensler, yet much more like yours.
I'd say your manifold looks better, more developed, having the 1st carb ahead of the 1234 ports, and perhap both carbs having the twist mount. Pretty much leaving the only issue to being momentum conservation during the transition from the Carb-base transition to the Plenum/runner topwalls. HIS
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 06-24-2005, 07:54 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by LouisianaGuy:
hmmm could carbon fiber 69 T/A or R/A GTO hoods be close behind ????
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 06-24-2005, 08:09 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Pretty much leaving the only issue to being momentum conservation during the transition from the Carb-base transition to the Plenum/runner topwalls. HIS </div></BLOCKQUOTE>
HIS-
Interesting point....I used the old trick (Wilson or Vizard?) of laying back the runner dividing wall at an angle to help reduce the momentum loss the charge would exhibit making the turn.....I dont know how well the trick works but? I looked at alot of newer Dart SBC BBC, BB Ford single 4 bbl intakes and some of the Edelbrocks and one can see that almost all of them implement the layed back dividing wall technique....or extending the dividing wall in a curved fashion into the plenum....supposed to help keep the momentum loss to a minimum. I dont own a Pontiac Victor....but from pictures it looks like they do have the dividing wall extending somewhat into the plenum.
Interesting about Brandywine Cyl...I was not following Pontiacs at all back then.
Old 06-24-2005, 12:20 PM
cgeise's Avatar
cgeise cgeise is offline
Esahlin -- were you at the Division race at PIR this last week end? Our Pontiacs held there own with the Chebbies pretty well.
Old 06-24-2005, 03:05 PM
I havent made it out to PIR this year....my car is in pieces...but I do need to make a trip to go and watch sometime soon.
