Old 06-06-2013, 11:21 PM
Default New Pitman arm
OK, guys, where can you find one? Neither OPGI, Ames or PY carry them.
Dr. Thomas Sowell
Old 06-07-2013, 09:53 AM
Rare Parts / NAPA can supply the second design 65 and 66 units. I'd call them on any others also.
Mike
former." --Albert Einstein
- Winston Churchill
Old 06-07-2013, 02:07 PM
Mike,
Will it work with the '61-64 steering links? I'm going to change over to a close ratio steering box.
Dr. Thomas Sowell
Old 06-07-2013, 02:17 PM
I have no clue, I'd call them. If nothing else they may be able to rebuild yours? They claim they will build any suspension part from 1930 up.
http://rareparts.com/
- Winston Churchill
Old 06-07-2013, 03:05 PM
Thanks, Mike. Mine MAY be OK, but considering I've already found a cracked steering arm, replacing or rebuilding the original one seems to be the most rational thing to do.
Dr. Thomas Sowell
Old 06-07-2013, 03:13 PM
Just got off the phone with Rare Parts. The pitman is considered a NON-WEAR part. They can re-bush and straighten the original. To manufacture a new one will be a MINIMUM of $275. Sounds like I'll be spending a little time with the bead blaster..........
Dr. Thomas Sowell
Old 06-07-2013, 03:45 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
Could you get someone to magnaflux yours?
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 06-07-2013, 06:04 PM
I never said it would be cheap!
- Winston Churchill
Old 06-07-2013, 07:00 PM
Engine-Ear's Avatar
hh62,
I concur with the '62 pittman arm being a non-wear item.
although I have not personally done it, a couple friends have put a second-gen F/B QR box on their '62, and IIRC they simply reused the original pittman arm...if yours is junk, I would scour either e-Rape or call the Steves (Barcak out West, Snyder in Indy).
Good luck and keep us posted on your progress...
Old 06-07-2013, 10:08 PM
That's the plan. Remove, bead blast and magnaflux. If there are any problem, send it to Rare Parts for rework.
Dr. Thomas Sowell
Old 06-07-2013, 10:10 PM
Matt,
I'm giving serious consideration to having my box converted to a quick ratio box. That way, it SHOULD fit back the way it's supposed to. I'm concerned about the structural integrity of all the steering components. The vehicle was involve in a one car accident when the ball joint failed(minor accident). When I found the cracked steering arm, I decided to magnaflux EVERYTHING including the "A" arms and spindles. Better safe than sorry.
Dr. Thomas Sowell
Old 06-08-2013, 12:36 AM
You'll not regret the quick ratio conversion. Add a couple sway bars while you're at it!
Mike
- Winston Churchill
Old 06-09-2013, 10:54 AM
Engine-Ear's Avatar
Thumbs up
Amen, brother.
Old 06-10-2013, 02:00 PM
Mike
Planning to, Mike. 7/8" in the frt., 1'' in the rear.
Dr. Thomas Sowell
