Old 08-12-2022, 11:53 AM
tooski tooski is offline
Default Found the problem
Popping in the exhaust. #1 compression was 15 psi down.
I just touched the pieces and they came away.
Name:	Damage 1 (1).jpg
ID:	596296   Click image for larger version
Name:	Damage 1 (2).jpg
ID:	596297   Click image for larger version
Name:	Damage 1 (3).jpg
ID:	596298   Click image for larger version
Name:	Damage 1 (4).jpg
ID:	596299   Click image for larger version
Name:	Damage 1 (5).jpg
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 08-12-2022, 12:14 PM
AG's Avatar
AG AG is offline
Something fall into the carb? Do you know the source of the foreign material?
Old 08-12-2022, 12:38 PM
25stevem's Avatar
25stevem 25stevem is offline
What got in there?
Is it magnetic?
I do stuff for reasons.
Old 08-12-2022, 03:47 PM
I believe I am diligent about small parts around the carb when the air cleaner is off. Perhaps not as it looks like something small did get in. The pieces are magnetic. Whatever it was might have broken up with most of it leaving with the exhaust. The pieces were embedded but came away when I barely touched them.
Frank M.
75 Firebird
Old 08-12-2022, 06:01 PM
Scott Thelander's Avatar
I had that happen once
on a 20 ' glasply
it was a center chunk of the throttle shaft that busted loose between the screws
on the reman q jet
looked very similiar
Old 08-12-2022, 06:47 PM
george kujanski's Avatar
Did that with an aircleaner wingnut..........it was not pretty.
george
Old 08-12-2022, 07:07 PM
Schurkey Schurkey is offline
93 Lumina Euro 3.4L DOHC 4-valve. Cylinder 2 clearly got screwed, but I have no idea when, and after replacing the head gaskets for unrelated problems, the engine ran great.
Old 08-13-2022, 12:27 AM
zippy's Avatar
zippy zippy is offline
Smooth the sharpness down on the piston and head and she will be OK!. Sharp edged create hot spots and unless you running the jagged edge of compression, Which I think unlikely. a smooth over to knock the sharps off and life will be good
Dan Pesonen
"If it ain't broke, modify somethin till it is"
The Following User Says Thank You to zippy For This Useful Post:
Old 08-13-2022, 06:36 AM
25stevem's Avatar
While you have it down that far I would pull the valves out of that chamber and confirm that neither Intake or exh valve sealing areas have been nicked up or scratched.
You can even first just pour rubbing Alcohol in each port and see if it weeps out.
Otherwise you will be tearing it all down again possibly.
If you feel lucky want to play the odds then clean things up, bolt the head on with the new gasket, set the valvetrain in place for that cylinder and do a compression test with no valley pan or intake bolted on.
While your at it look close for scratched and nicks on the bore walls.
The Following User Says Thank You to 25stevem For This Useful Post:
