Timing cover divider plates
So
I am cleaning up a couple timing cover s today to sell and I have 2 different styles of plates 1 is cast aluminum and steel The other is the standard steel steel Was the cast aluminum early 64??? Thanks Last edited by Scott Thelander; 07-11-2022 at 03:10 AM. |
ok
theres a part number on the back 9773375 and I fingered it out thanks guys for the post 1 year ago https://forums.maxperformanceinc.com...d.php?t=851967 |
Fingered???????????? Of course you did.
Practicing social distancing for 65+ years |
I could swear the original plate on my '65 GTO is aluminum. Engine cast date is Feb. '65. I coat all my plates and inside the timing covers with Glyptal to prevent electrolysis.
Jeff |
I painted mine with Rustoleum enamel. Not assembled yet and I was thinking about using POR 15 instead. |
No, and it's been 12 years. But I've used it in other engines and have never had it come off or fail. It sets up like porcelain or epoxy. Very hard and durable. And not expensive, either.
Jeff |
Geeteeohguy,
I've used Glyptal in engine block lifter valleys and never had a problem but never thought about using it for the timing cover. The electrolysis issue and the general corrosion of the timing cover is why I initially applied the Rustoleum. Sounds like the Glyptal might be a good bet. |
I used POR 15 on a timing cover inside the water pump area. Six months back on the road and I noticed little flecks of black about the size of metal flake. Even though I had media blasted the cover it only took six months for it to start flaking off. Over time the impeller of the water pump then took the small chips of POR 15 and reduced them to micro flakes. It would be interesting to know whether the Glyptal would hold up any better.
Just for the record, the repairs I have made with JB Weld started to fail at about the 7 year mark. It seems that both instances the problem might have been with the antifreeze slowly making its way under both the POR 15 and JB Weld. I'm wondering whether that even blasting and cleaning the surface still has some embedded corrosion that finally lifts the repair.
Thread Tools | |
Display Modes | |
