Old 11-17-2014, 08:48 PM
Hooter's Avatar
Hooter Hooter is offline
Default 67 Bonnie With Skirts - 17" Wheel/Tire Combo Question
Picked up a really nice 67 Bonneville convertible last week. Body on restoration done 15 years ago by a buddy of mine for his now deceased dad. Everything new/rebuilt. The factory 14" wheels and hubcaps just aren't doing it for me and will start looking over the winter for some 17" or similar size wheels. Really liking the MB style old school wheels. The fender skirts will stay on. What sizes will fit front and back without rubbing along with required back spacing? Tried doing a search on here but most hits were more for 8 lugs or rally 2's.
67 Bonneville ragtop
Old 11-17-2014, 08:57 PM
Hooter's Avatar
Originally Posted by Hooter View Post
Picked up a really nice 67 Bonneville convertible last week. Body on restoration done 15 years ago by a buddy of mine for his now deceased dad. Everything new/rebuilt. The factory 14" wheels and hubcaps just aren't doing it for me and will start looking over the winter for some 17" or similar size wheels. Really liking the MB style old school wheels. The fender skirts will stay on. What sizes will fit front and back without rubbing? Tried doing a search on here but most hits were more for 8 lugs or rally 2's.
Here's a crappy pic
Old 11-17-2014, 09:49 PM
20milecar's Avatar
20milecar 20milecar is offline
Don't have any answers but I'm wondering the same.
Old 11-17-2014, 11:55 PM
MCronkGTO MCronkGTO is offline
Here are some pics of my 67 GP with 17" wheels and fender skirts. Wheels are 17x8 4.5" BS. Tires are 255/40/17. When it is time to replace the tires I might go a little taller with a little more sidewall for a smoother ride.
Mark C
ID:	382307   Click image for larger version
ID:	382308   Click image for larger version
ID:	382309   Click image for larger version
Old 11-18-2014, 12:53 AM
OZZIEVILLE 67 2 door's Avatar
OZZIEVILLE 67 2 door OZZIEVILLE 67 2 door is offline
My 67 has 225/60/17 front,235/60/17 rears..
Just a note ,stud pattern is 5 on 5.
With my mags I had to machine the rear centres out to fit the wheels because of the axle that protrudes out from the drum..
John L.
Old 11-18-2014, 08:03 AM
Hooter's Avatar
Thanks guys. Exactly what I needed.
Old 11-18-2014, 09:40 AM
Hooter's Avatar
Mark - how close to the skirt is your tire? I"m assuming the wheel well is the same size as on my Bonneville.
Old 11-18-2014, 05:28 PM
Close but does not rub except for one condition. If I go up an incline (driveway) at an angle the body will roll to one side and occasionally a light rub. Not enough to damage tire or trim on fender skirt. I will take a measurement tonight.
MarkC
Old 11-18-2014, 05:49 PM
incommunicado incommunicado is offline
Default 67 Bonnie wheel and tires
These are some I ordered a few years back. If I had it to over again I would probably go with 15's or 16's. The 18's are very hard to find tires that will work and in my opinion ride to hard. I do like the look though.
18 X 7 alum. billets from Wheel Vintiques w/ 4 3/4 B. S. They barely clear front and back, will rub the inside fronts at full turn, and I had to clip the bottom front edge of the front fenders. Hardly noticable though. Definately fills out the wheel wells.
The last picture is of a 67 GP I am working on now, 8 lugs with 15 X 7 wheels and redlines.
Name:	Myrtle- after Aug 003.jpg
ID:	382347   Click image for larger version
Name:	Myrtle Picture January 2012 004.jpg
ID:	382348   Click image for larger version
Old 11-18-2014, 11:25 PM
I saw your Bonneville in Dayton a couple of years ago, beautiful car. Is the GP your working on a 4 speed (saw the long tailshaft Muncie on the floor)? I agree that these low profile tires with very little sidewall ride stiff. I have 17" wheels on my GP and when it is time to replace the tires I might try and find a little taller tire or go to a smaller rim to get more sidewall and a softer ride. I have considered a nice set of 8 lugs in a 15 or 16 inch wheel but not sure how expensive that is?
I did measure the clearance on the rear wheels/tires to the inside of the fender skirt. It varies from side to side a little. Passenger side has about 1/2" front and almost 3/4" at rear of fender skirt. Driver side is a little tighter with about 1/4" front and 5/8" rear clearance.
Mark C
Old 11-21-2014, 09:05 AM
Default 67 GP Convert 428 4 Speed
Mark C
yes a 4 speed car, and I would budget 3K+ for a set of 8 lug drums, new 15in wheels and new tires. I agree on the clearance in the rear, as my experience in the Bonnie was 1/2 inch +, -.
Old 11-21-2014, 01:48 PM
20milecar's Avatar
Hope I'm not thread jacking but I'm in the same situation. I think I'm going to go with torque thrust 16x7 4"bs with a 245/50/16. Hope I'm making the correct choice
Old 11-23-2014, 10:11 PM
Here is a great link to compare tire sizes (actual measurements). There is some variance between brands of the same size tire but these are a good reference.
http://tire-size-conversion.com/tire-size-chart/
MarkC
Old 11-26-2014, 01:13 PM
TimeWarp TimeWarp is offline
There is a wheel fitment tool you can buy, and bolt it onto your hub, set it for different wheel sizes, etc and spin it around to check for inside and outside clearances. The one I know of is called Percy's wheelrite, but there may be others. One guy on another forum bought one then resold it after to recoupe some of the $ spent. I think they are $75-$95.
Old 06-27-2017, 10:56 PM
Nickv's Avatar
Nickv Nickv is offline
I just purchased 17x8 Cragar 69 wheels with 4.5" BS for my 67 GP. Since I think larger wheels look better with more sidewall I'm going with 225-60/17 tires. They will be essentially the same dimensions as my 225-70/15 tires I now have on the car now.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecarsgalore.com
www.nikivee.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger ScatPack 392, 6 speed
2017 Ford Explorer AWD
