Has anyone ever tried to use the stock size power brake booster with tall valve covers in a 67-69 bird??
Honest dad, that 455 on the side of the block is a serial number
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
Not in a '69, but I had a set of Moroso valve covers in my '76. I'm using the same valve covers in my '69, and in the picture below you can see my clearance method:
Tools Required: 1. Big Hammer 2. Bottle of Beer Procedure: 1. Support valvecover securely on wooden bench 2. Drink some beer 3. Hit valvecover smartly with hammer 4. Drink some beer 5. Test fit 6. Repeat as necessary I am *NOT* running a stud girdle, but I am running a set of Crane "Silver" Roller Rockers/Adjusters, and I've never had a clearance problem. |
here is mine with short valve covers
(Some things in life are certain: taxes, death and being screwed by an attorney) |
Tall covers hit the stock power brake booster. You can give them a little ding for clearance or just let the rocking of the motor put one in for you.
I speak from experience. |
NOtice how both cars don't have the hoods closed? Looking at this, I'm asking myself if the Preformer and drop down K&N will allow my 68 hood to close? So friends what is I gonna fine out, once I wedge the 455 in huh? Now don't be that way, it ain't gonna hurt to let me know in advance. I have learned enough by trying things for myself honest !! Even learned I didn't understand how come a 7/16 socket can't fit a hidden 1/2 inch nut so there !!
Now, the answer to my hood question pleaseee ???? Build it fast, build it right, hold On TIGHT !!!
Build it fast, build it right, hold On TIGHT !!! |
did it on my 69 350 even with hood insulation...don't know about 68
can you hear me now? is this thing on? test 1 2 1 2
can you hear me now? is this thing on? test 1 2 1 2 |
mine has a performer rpm with elite series air cleaner and the hood does not hit. its only off for the repaint.
