Tri-Power Tech 57-66 Tri-Power Talk
Old 07-21-2017, 10:20 PM
SR-71 SR-71 is offline
Looked at a 27,000 mile original one owner Tri-Power 4 speed 66 that had a yellow spring on it.
Old 07-21-2017, 10:41 PM
Tom Vaught's Avatar
Boost Engineer
I have seen 97% of the 66 Tri-Power cars (that I had looked at over the years (closely)),
with the Yellow Spring and THREE 66 Tri-Power GTOs with the Blue Spring, and as I posted in the beginning of this thread assumed the owner swapped springs at some point.
Tom V.
Old 07-23-2017, 05:01 AM
Kenth's Avatar
Kenth Kenth is offline
I found in the 1967 MPC spring #9784823 for 1966 T/8 and 1967 T/8 exc, cruise control.
1963-65 T/8 uses spring #544922.
1967 T/8 w/cruise control uses spring #9789460.
In later MPC´s the 9784823 were superseded by 9789460.
If the 1967 T/8 exc, cruise control uses a blue spring so would 1966 GTO Tripower?
And if, is the 9789460 blue also?
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 07-28-2017, 08:47 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
I wonder if it varied by plant. I know that both mine and 60sstuff Fremont built cars came with the blue spring.
Old 08-05-2017, 08:22 AM
DANTIP DANTIP is offline
My original Fremont tri-power return spring in post #10 is most-likely original. May be a "plant-thing".
Old 08-08-2017, 05:45 PM
Tom Vaught's Avatar
Boost Engineer
I personally never say "never happened" as I have seen personally too many "differences" with 64-66 Tri-Power Carb vehicles over the years to question anything that plants did.
Just a thought that came to me:
If a spring vendor won a contract for a blue spring for one plant and the spring proved out to be acceptable on several applications besides Tri-Power cars, then the possibility exists that the Blue Spring would migrate to other plants in some fashion. Especially if the design could be used for other induction systems with say a "carb extension" change on a given carb.
Tom V.
Old 08-09-2017, 04:17 AM
Kenth's Avatar
Wasn´t all engines assembled at the Pontiac plant and then shipped to car assembly plants?
http://www.musclecarfilms.com/images...mbly_photo.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 08-09-2017, 05:04 PM
Tom Vaught's Avatar
Boost Engineer
That is what I always assumed. Keith Seymore or Mike McCarty's Dad worked in the Pontiac Area in different plants. Keith might be able to lock that assumption in.
Tom V.
Old 08-12-2017, 11:13 AM
66GTO Jim's Avatar
66GTO Jim 66GTO Jim is offline
Yes. Plant 9, Pontiac, Michigan
Name:	Pontiac Engine Plant 1966.jpg
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig"
