Old 11-04-2022, 10:23 AM
TOPHER TOPHER is offline
Default 66 A body Radio and speaker wiring diagrams?
I've been cruising around the web, checking all the service manuals for '66 GTO (including the laminate), and for the life of me, I cannot find any wiring diagram supplement covering the radio and speakers. Anyone have either a diagram or something to show color, connections, etc?
Old 11-04-2022, 10:28 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I checked my '67 Cutlass FSM - it only shows power and ground to the radio. Sorry...
Mike
Old 11-04-2022, 10:39 AM
Maybe M&H can supply me with something...
Old 11-07-2022, 07:09 AM
Jeff Hamlin's Avatar
Not sure what exactly you're after but here are the basic connections for '66-'67.
BLACK-GROUND.
GREEN-SPEAKER.
YELLOW-12V ACC POWER.
The factory dash hardness has the male connector for plug-and-play installs.
Are you missing this?
Hope this helps.
Name:	66-67 RADIO CONN 2.jpg
ID:	601821   Click image for larger version
Name:	66-67 RADIO CONN 1a.jpg
ID:	601824   Click image for larger version
Name:	66-67 RADIO CONN 3.jpg
ID:	601825   Click image for larger version
Name:	66-67 RADIO CONN 1.jpg
Old 11-07-2022, 01:47 PM
That's awesome, thank you!
Old 11-07-2022, 02:16 PM
Kenth's Avatar
Kenth Kenth is offline
You will find all needed info regarding radio in 1966 Tempest Service Manual Section 15 (Accessories).
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-08-2022, 08:56 PM
GT182's Avatar
GT182 GT182 is online now
Do you have an AM or FM radio? Connections might be different. And If you get yours hooked up and have no sound or just a buzzing from it, you will most likely need a new speaker.
That's why I added a modern Kenwood with a USB plug under the dash. It's stereo and I download music (MP3s) to play. Works great and cheaper than buying a converted GM Pontiac AM/FM to replace your AM. Don't cut up your dash to add any other radio but the Pontiac originals. If you do, you will be very sorry later on. I know many that did that years ago and most are still sorry, but a majority that did have replaced their dash.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-09-2022, 08:02 AM
I agree with the OP the SM has very limited info.
As far as connections the color code on the wiring is the same regardless.
Old 11-09-2022, 12:24 PM
Kenth's Avatar
There is 9 full pages, 15-2 to 15-11, of information in the service manual on all aspects regarding radio installation. This is all but limited info.
JMHO
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
