Old 07-19-2023, 01:23 AM
bonnevista's Avatar
bonnevista bonnevista is offline
Default 1972 Grand Ville. Lares power steering box. More steering effort
After more than 40 years of driving old cars with old parts, I decided to fit a new Lares power steering box that I bought from Summit. It has the faster steering ratio with about 2 1/2 turns lock to lock, compared with the old one of about 3 1/2. The steering box bolted up with no issue. Apart from quicker steering, the main thing I've noticed is the much increased effort required to turn the wheel. Don't get me wrong, it's still 'power steering' and I can still 'palm' the wheel when turning, but it's a lot heavier than the old steering box. Has anyone else had a similar issue and as this a new part, rather than reconditioned, is it likely to have a break in period and loosen up with some miles? Btw, I thoroughly flushed the pump and lines before filling it with fresh fluid.
Old 07-19-2023, 07:34 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I put one on my car recently and it is slightly stiffer but not a huge difference. I'm happy with it.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 07-20-2023, 12:55 AM
rjpaige3 rjpaige3 is offline
The faster ratio boxes are _generally_ higher effort on purpose. It may loosen up a bit, but it won't ever feel like the standard landbarge box.
Old 07-23-2023, 09:55 AM
62olds 62olds is offline
I am thinking about getting the same box for my 1970 Lemans Sport. I am looking for a more modern feel to the steering.. Some have said that it too sensitive on the highway and you really need to pay attention. What is your opinion? Is the 10:1 too quick for highway use?
Old 07-23-2023, 11:30 AM
OCMDGTO's Avatar
62, I got the Borgeson 800130 box at 12.7:1 & it is fine on the highway. Really not much different from stock.
Chris D
Old 07-23-2023, 06:53 PM
This box has really good reviews. I believe it requires a different rag joint and adapters for the lines. Is that correct?
Old 07-23-2023, 07:44 PM
OCMDGTO's Avatar
It came with adapters for the lines and a rag joint. The adapters are basically round discs like a washer for the stock lines to work and the joint looks like a polyurethane disc.
Chris D
Old 07-23-2023, 07:56 PM
Thanks for your input.
Old 07-24-2023, 11:56 PM
bonnevista's Avatar
On the highway, it's fine. It just gives the feel of a more modern car. You won't change lanes when you sneeze...
Old 07-25-2023, 05:31 PM
You installed the part# 10972 box. Is that correct? Thanks for your reply. Just wanted to be sure that I order the same unit.
Old 07-25-2023, 07:43 PM
bonnevista's Avatar
That's what I ordered. They also have the #201 rag joint/coupling. I ordered that as well...
Old 07-26-2023, 05:16 PM
Thanks for your feedback.
The Following User Says Thank You to 62olds For This Useful Post:
Old 07-26-2023, 05:19 PM
Thanks again to all. Borgeson is a good option but I don’t want to change the fittings and the rag joint. I have a new one from Ames.
Old 07-27-2023, 07:19 AM
OCMDGTO's Avatar
62, I should have clarified the adapters look like a small wedding band and fit in the threaded female part of the box. Stock lines then work. Very easy and mine don't leak.
Chris D
Old 07-27-2023, 09:08 PM
I’m still unsure of which box to order. Thanks for the info on the hoses. I have already spent $50 on the new coupler. I really don’t want to buy a more expensive box and not use it. Too many choices is sometimes a bad thing.
