Old 12-03-2021, 11:00 PM
Default Where to buy procharger
I’m thinking about a supercharger where is the best place to purchase it? The most complete kit to put on a traditional Pontiac 455. Thanks.
Old 12-04-2021, 12:58 AM
JLMounce JLMounce is offline
Probably Luhn Performance. They can supply their bracket as well as the head unit.
-Jason
1969 Pontiac Firebird
Old 12-04-2021, 03:08 AM
R 70 Judge's Avatar
Procharger kit
http://www.luhnperformance.com/ati.html
Vortech kit
http://www.luhnperformance.com/vortech.html
Don’t overlook the Vortech YSI. It’s a great blower. A friend ran one on his Buick 455 for years trouble free.
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 12-04-2021, 10:03 PM
A T-Trim Vortech Supercharger made 862 Dyno HP on Steve Morris Dyno. 13 psi boost
A YSi will make more HP possibly as much as 1000 real hp on a dyno.
Brian Hedrick ran a Procharger on his Firebird for years, Actually several Procharger units.
Without a really good intercooler on the front of the car, they make a lot of heat.
Not needed with other methods of cooling the charge, for a drag only deal.
(Water to Air intercooler mounted in the passenger seat location.)
How much power do you want to make?
Old 12-05-2021, 11:19 AM
GTOGEORGE's Avatar
In order to get optimum numbers you WILL need either open headers or a free flowing exhaust among other things, So your numbers WILL very up or down…….just saying!
GTO George
The Following User Says Thank You to GTOGEORGE For This Useful Post:
Old 12-05-2021, 01:31 PM
GTOGEORGE's Avatar
I remember a long time ago when i was running 8.90's on racing gas i switched to 2 1/4" headers from 2" and picked up a little bit over 2 tenths no other changes!
GTO George
Old 12-05-2021, 02:10 PM
Since header tubes measurement is based on tube outside diameter, and even the thinest / lightest header wall thickness would probably be .060", a 2.0" header tube is actually 1-7/8" internal diameter. A 2.25" header tube is 2-1/8" internal diameter.
So you made a big change in the flow capability of your exhaust Zoomies.
Old 12-05-2021, 02:38 PM
GTOGEORGE's Avatar
.250"
LOL!!
Hence the 2" to 2 1/4" increasement
GTO George
Old 12-05-2021, 03:15 PM
Smart move there.
Old 12-05-2021, 04:32 PM
GTOGEORGE's Avatar
On my engine 13 lbs of boost is making around if not more than 1,400 HP.........better flowing heads, bigger camshaft.....etc! It all depends on the engine combo1
GTO George
Old 12-05-2021, 04:39 PM
GTOGEORGE's Avatar
A long time ago B & M had one of the BEST Real Life numbers book on Supercharging, it should the HP, BOOST, TORQUE numbers of different heads, header sizes, camshafts, different blower speeds......I wish it was still available!
GTO George
Old 12-05-2021, 05:08 PM
blueghoast's Avatar
GTO George
What are your cam spec's George if ya don't mine me asking.
You can PM me the spec's if you like Thanks. If not I under stand.
GT
Old 12-05-2021, 06:23 PM
Stan Weiss's Avatar
.250"
LOL!!
Millwrights, Racers & mechanics fix things that engineers mess up!
GTO George
Really!
It is area of inside diameter the pipe that counts..
Going from 1 7/8" to 2 1/8" is 128.44% increase
Going form 2" to 2 1/4" is 126.56% increase. Close but no cigar.
Stan
Pontiac Pump Gas List
Old 12-05-2021, 06:30 PM
Stan Weiss's Avatar
GTO George
Do you have a dyno sheet or time slip that shows that?
Stan
Old 12-05-2021, 07:07 PM
You have to assume that the Drive losses would be high to drive that BDS unit.
The drive losses on a centrifugal (Procharger) supercharger are lower for sure.
The Original Thread Post #1 was discussing a Procharger Supercharger.
Old 12-05-2021, 07:08 PM
GTOGEORGE's Avatar
GT
No problem I have no secrets, in my opinion they are no tricks or secrets just common sense! I’ll have to look them up.
GTO George
Old 12-05-2021, 07:29 PM
GTOGEORGE's Avatar
Which would magnify the hp gain even more!
GTO George
Old 12-05-2021, 08:03 PM
GTOGEORGE's Avatar
GT
Advertised duration: @.050" Lobe size: Lobe separation: Lash:
Intake 300* 272* .440" 110 .022" cold .028" Hot
Exhaust 316* 288* .440" .024" cold .030" Hot
Intake opens at 30* BTDC closes 62* ABDC
Exhaust opens at 78* BBDC closes 30* ATDC
Overlap is 60*
Not the perfect cam but i needed one and DCI had it on laying around. Thanks Don!
GTO George
Old 12-05-2021, 10:40 PM
About 5 degrees at .050 smaller than the camshaft Jimmy Keen ran in his 347 cid engine when he was the
1998 National Super Street Champion. He ran his engine to 9,000 rpm every pass with the two speed glide trans.
(He went thru a lot of Power Glide Trans. Sometime 3 in a week-end of racing).
He had about a .786 lift at the valve.
Agree, your cam is not the perfect camshaft but will work until you could find the right one. Jimmy's Cams were ground by Harold B.
He was racing against the best at the time, Billy Glidden, in Super Street for a National Championship 1998.
You are Bracket Racing. But if the camshaft does the job go for it. Don did you a favor. And it should be close enough for a bracket engine.
By the way, Jimmy could run 7.50s with his 347 cid Mustang. Just like Brian Hedrick did with his
Procharger car. And the thread IS about a guy wanting to buy a Procharger for his PONTIAC engine.
Talk to Brian Hedrick grandam1979. If you pm me I will get his cell number off my phone to you.
Old 12-05-2021, 11:05 PM
GTOGEORGE's Avatar
I’m thinking Brian only ran mid 8’s at 13 lbs of boost!
GTO George
