Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 05-09-2020, 10:24 AM
AIR RAM AIR RAM is offline
Default JE PISTONS - 455 +.040 bore.
I purchased these pistons USED from a this Forum over 10 years ago. They where going to be used on my .040 over Pontiac 455ci build. I have since decided to build a stroker 496 and did not end up needing these pistons.
They are used, I had the tops ceramic coated and the side skirts coated with a friction barrier by a local machine shop. They have sat ever since. I want to get rid of them before they become a set of expensive ash trays.
With the 4.21 stroke 4.55 crank, 6.625 Rods, and the 1.501 pin height, these would sit .009 below the deck of a 10.24 455 block.
The dimensions are.
Diameter at skirts: 4.199
Pin OD: .980
Compression height: 1.501
For more pics, visit the link below.
Click here for more pics and to purchase using Pay Pal or credit card.
Still have program engineering 4-bolt mains, 455 N Crank, factory Windage tray and this set of .040+ JE Pistons for a 455 for sale... They are all in the link above..
SPEED SAFE, NICK
Name:	JE Pistons 517F 2.jpg
ID:	539723   Click image for larger version
Name:	JE Pistons Skirts 4.199.jpg
ID:	539724   Click image for larger version
Name:	JE Pistons Pin .980.jpg
ID:	539725   Click image for larger version
Name:	JE Pistons Pin Height 1.010+.49=1.5.jpg
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 05-09-2020, 04:30 PM
slowbird's Avatar
slowbird slowbird is offline
Valve relief cc? Pic of the tops?
Old 05-09-2020, 04:52 PM
There are more pics in the link above... I honestly do not know the CC's of the valve reliefs.
Willing to get any measurements you need... however I dont have the ability to check the cc's of the valve reliefs.
I have attached a pic of one of the piston tops...
SPEED SAFE, NICK
Name:	JE Pistons top.jpg
Old 05-12-2020, 10:03 PM
62cat421sd 62cat421sd is offline
interested price vance 7402250390
Old 05-13-2020, 05:59 PM
Sorry, I completely forgot to list the price.
Price: $450.00
plus $25.00 S&H
SPEED SAFE, NICK
Old 05-13-2020, 09:10 PM
joes455 joes455 is offline
I thought a 455 040 over needed a 4.190 piston
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 05-14-2020, 07:16 PM
Yes, you are correct.
These are 4.190 pistons however the friction coatings added to the skirts have added .009 to them....
SPEED SAFE, NICK
Old 05-15-2020, 10:17 AM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
You have a PM. Interested in the pistons.
Thanks - Kevin
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
Old 05-16-2020, 07:57 PM
Responded to your PM...
Pistons alone weigh 532 grams
With Pins and retainers they weigh, 690 grams.
Thanks for looking.
SPEED SAFE, NICK
Old 05-20-2020, 05:29 PM
Still available.
The dimensions are.
Pin OD: .980
Piston weight: 532 grams
Pistons W/ Pins & Retainers: 690 grams.
Price: $450.00 plus $25.00 S&H
SPEED SAFE, NICK
