Old 09-22-2022, 09:09 PM
65sport 65sport is offline
Default 326 timing cover/water pump
The inner metal plate in the timing cover on my 65 is corroded internally and partially rusted away on the "cut out", and I can't get it separated from the cover for replacement or repair. The aluminum on the other hand is fine.
I've got a 66-67 timing cover the plates fall right out and are in good condition, but the aluminum is severely pitted on all surfaces.
I want to take the plates out of the 66-67 cover and put them in the 65 cover.
I've soaked it in penetrating oil but if I use more force I'm afraid I will break it.
Any suggestions ?
Old 09-22-2022, 09:42 PM
Found out despite appearing to be rusty steel, it's all rusty aluminum. Trying to delete the post.
