#41
That’s right forgot he changed over to a BOP. Kinsler was one who made 995 hp I rounded it off to 1000 hp.
I ran 10.30s with a pump gas 406 with home ported 62 heads in ‘89. Tom V. now has my intake. Has a 2 inch phenolic plenum spacer. Original Wenzler dual quad ended up being quicker.
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post: | ||
#43
What I am saying is there had to be 2 tenths on a fresh build. Took me years to get it down to 10.80s . When I race the High Ports for a season or two the HOs, re done will go back on and I will see how low I can go with them on a real engine. Going to run small stem valves, 300cfm potential. Will try the Warrior and a Victor. I bet I can get the car down under 10.50s with 9-1 CR, maybe lower. Kens car, E heads by Sd Dave, intake by Gabby, trick carb. I am sure the car was pretty light. He was a big street racer in LA. Said he beat everyone. Running a 400 it would be tough to get he CR over 12-1 anyway with E heads. The used Comp rollers in my 455 were bought used from Kens dad. Old junk. I will bolt the Warrior on the High Port engine with the 1/8" miss match on top just to see what happens. Just bracket race so it will not hurt to try. |
#44
I would guess the 1970 392 IH topped with a Holley 1050. Got 1 on my PMD 472
#45
I also have an original Wenzler T/R intake that works very well with dual quad Holleys according to the 1/4 mile racer I got it from. That intake will be a EFI intake at some point. I own a single 4 BBL top. I have owned Wenzler Guttsram intakes in the past and got them to work on less than 500 cid engines by installing "stuffing blocks" in the intake runners to reduce some of the volume and taper of the runners. Tom V.
#46
Let us know what Gach ? What does my engine have to do with Kens ?
Kens exploits are well known. Very good racer with a real race car. Street racer so he probably gave it a shot of juice. Even if he did it was the quickest 400 I know of. No intake is going to make that much difference in power between mine and Kens old car and you know it. Its about the whole combo and you also know that. So why this ? The whole point is the Warrior with a bunch of work can be a very good intake on smaller engines. Paul has made 2 posts stating such. And even without a bunch of work on ported iron head also works well. Is it worth it ? No but people do what they do. Still the best looking Pontiac intake. |
#48
When I brought this up years ago someone commented on a Mopar (318 ?) engine that had a single plane intake from the factory.
#49
Hey someone may have a Warrior laying around or can get their hands on one cheap. That likes the nostalgic part of running one. You know period correct type of build I love those type of builds. I’m sure most likely thats the case with Pual customer. For some reason you have it in your head and are taking my comments personal. The tread starter is about possibly reproducing it. I assume for nostalgic reasons. Like Tom s has done with the one he had reproduce. Love it.
Yeah you lift that part out about him spraying, I knew that. know Ken well. I just thought it was miss leading. Nitrous can make up for allot of sins, take up to a full second off your ET. There’s a reason why they stop making the Warrior that’s not to say there wasn’t some GREAT builds.
Personally I ran a Warrior on a street /strip 455 HO 71 Trans Am back in the late 70's and ran 11.30's with a quadrajet, solid roller cam and stock 197 heads.. There was nothing else back in the day and i wouldn't mind just having one on my 70 Trans Am now...and i ran the Tunnel Ram on a Pro Street car...I was never impressed with it, But i liked the look...but in 1982 .there wasn't much to choose from.. Getting the single 4150 Warrior under the hood might be a big problem as i want to keep the stock steel hood on this car..but i have the Performer RPM with the factory shaker that works on it now...with a factory looking air cleaner. That's why i'd like to get a height dimension.... If anybody has any Warrior intakes for a 4150 or maybe the tunnel ram..please let me know! Really appreciate all who responded to this thread..been very enjoyable for me..Thank you all.
#52
When I had the Quadrajet Warrior on My 71 Trans Am back in the day I had a glass hood from HO Racing and if i remember had a taller scoop we attached , Plus i had those short aluminum body mounts from Herb Adams
. That's why i don't know if it will fit the stock steel hood. , maybe without a spacer it might. I had 2" open..Just for nostalgia reasons and if a guy took it to the track..add the spacer ??? or throw the Performer RPM back on or ???... and the Pro Street Tunnel Ram car had a VFN , Obviously with a hole cut...Still love the look of the Warrior!! Last edited by catc; 04-28-2022 at 09:29 PM. |
#54
The intake Paul post needs to be cast, it out powered a ported victor.
#55
I could be wrong but I think even without any spacer that it’ll fit under a stock hood, with a Breather.
It would be a seller on looks alone with performance to match. BTW, Gachs Victor cast up would be a seller too. |
#57
Hi Paul
that was the intake you got from me Did you finished up the port work? |
#58
Hello, no its not.... I'm still working on yours
#59
I guess you guys dont realize how hard and expensive it is to reproduce a intake EVEN with 3D scanning and printing!Just to have someone to do the computer work alone to go in and make a wide port version of the Warrior could cost 10K in computer work.Custom CNC billets are the way to go now.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
#60
On one version of the Year One Bandit Trans Am project with a 535 combo Jim Butler used a Victor intake with the carb flange milled down 0.650" to help it fit under the hood.
With the cut down intake he used a WFO drop base unit for the TA Shaker scoop. Tested on the engine dyno at peak power rpm it gave up about 15 hp by milling the intake. "A modified and ported Victor intake with a Holley HP series carburetor" https://butlerperformance.com/images/M145286875.jpg On my current 505 street engine prior to the fuel injection I did the same thing with a Victor intake & HP950 carb. On the dyno I lost about 8-10 hp at peak power rpm after milling the intake flange 0.650". Not a race deal so for me I did not miss the 8-10 hp. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 04-29-2022 at 11:14 AM. |
The Following User Says Thank You to Steve C. For This Useful Post: | ||
Closed Thread |
