Old 09-09-2015, 02:21 PM
simon455's Avatar
simon455 simon455 is offline
Default 69 firebird street/strip
69 firebird, 13.5x30 or 315 drag radial ladder bar stock suspension car
Trz a arms, flaming river rack, ssbc drop spindles, moroso coils, strange front single adjustable, rear double adjustable afcos, build, braced 9"
Strange iron center section, 35mm strange axkes, light weight spool, billet yoke,
Drilled wilwoods all around, gold weld magnums,15x3.5 and 15x12 currently with a 315 drag radial, vfm light weight fibreglass clip, custom hood, lot attention to detail and fit/gaps, 12pt cage, poly buckets, stock dash/cluster plus auto meter gauges, pistol grip shifter, build 400, rollerized, manual body with brake, custom tci pro x 4000 stall converter, working lights, interior
71 ho block and crank,tci rattler balancer .60 over, h beams, icone dished Pistons, hv pump, canton pan/pick up, 330 cfm butler heads, ti. Retainers, 1.5 scorpion rockers, dougs ceramic headers
Sheet metal butler covers, flat tappet 599 lift cam, crazy ported 4500 warrior intake, shaker455 1050 2 circuit dominator (works awsome) msd billet dizzy,
Csr electric water pump, alum fabbed rad, electric fan, line lock, 3" stainless exhaust out the back with x pipe and borla x1 pro mufflers, Molly shaft 3150,
Ran 10 34@132, first trip to the strip ever on 91 octane, should do better with more seat time, cruise the car on weekends, been to shows, dream cruise, runs awsome, does not overheat, car is located in Toronto, Canada
For more questions pics, text 416 553 8ooo
Or mlodysimon2002@hotmail.com
Asking 32k
Old 09-09-2015, 08:38 PM
simon455's Avatar
Some more pictures can be seen here:
http://public.fotki.com/simonsq/firebird/
Some are older with old motor from "initial build"
Also to edit post above, fuel system consists of 10 gallon alum cell, magna fuel
Pro star 500 pump with filter, magna star regulator with boost reference, braided lines land alum tubing along frame rail
Old 07-07-2016, 11:31 AM
simon455's Avatar
Car is listed also on yellowbullet, more pictures there, looking for 30k or best offer
