Fuel pump Reccomendation for 67 Sprint
Looking for advice and opinions for the best original style fuel pump for my little Sprint (67 LeMans), manual transmission, stock engine build, A/C, etc...Brand, manufacture, distributor and or part number would be vey helpful. Thank you.
Tim john--- |
your model will have 2 different pumps.
What is your return line like? when was your car built?
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Thanks Cammer for the interest, Accordinmg to the firewall data plate it reads "09D-0595. Car is a 67 Lemans Sprint 6
Tim john--- |
you didnt answer what your return line is like
67 Sprint 6 LeMans Fuel Pump.
Gentleman,
Here a few photos of my current fuel pump, do not know if it is the factory original or not but would like to replace so that I know exactly what I have. Would like to replace with the best quality option. Engine is factory stock, three speed manual floor shifted w/ A/C. Thank You for any and all advice. Tim john--- |
I can tell by pics that its not the factory correct pump
again,what does your return line look like
Cammer, can you explain in what you need me to describe ? Do you want me to describe where the return line is run under the chassis ? I have included a few additinal photo's Do these help you identify it properly and if not please explain what else you need. Thank you.
Tim john--- |
Jeff I'm pretty sure your looking for a 40596 pump '67 4bc w/AC.
Note the taller inlet on the pumps pictured below. It looks like you have a 40494 1bc pump on there. It will work I ran one for a few seasons before finding a correct one for the '66. I think it is maybe a 1-1.5 psi less then the 4bc pump.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
yes thats a good pic of return line
sometime in mid year 67 they changed the return to be in the pump. Yours is in the filter. Ive had 3 others like that and one with line on the pump. I repro the fuel and return lines if you need any Ill look and see if I have any NOS pumps otherwise use whats on it now.
Thanks guy's for identifying what I have. If either of you have the correct pump I surely have interest so please let me know. I would not mind replacing the original lines as well. I will do so when I can come up with the correct pump. Thanks again for your Nancy Drew detective work.
Tim john--- |
Pumps
Tim,
I have GM 40508 pumps, this is what I use. This would work on yours as well since both are 230s They have been inside stoarge but due have shelf wear and could use a wipe. They are in perfect working order. The 2nd pump I show is a "rebuildable" Capac unit looks almost stock but best part is they can be serviced/rebuilt unlike our sealed GM pumps If you look at that pump you will see the addition of the return. I think this is the "2nd design" Cammer refers to. If your '67 is an early build then the fist pump matches what you should have unless someone cut/caped and/or removed the return line which was used on the later OHCs w/AC. PM if I can help further. Cheers.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 04-15-2014 at 06:39 PM. |
66Sprint6 & Jeff, Thank's guys for the leads and moments ago I clicked on the link 66sprint6 provided and hit the "buy it now" for the 40596 pump. Jeff, when it arrives I will give you a report on its functionality. If it fails to work I would like to purchase one from you but seeing that this one on ebay was the correct number you said that I needed I figured it would be best to just grab it given the opportunity. Thanks to everyone who has stepped up to help me out. Great place, great friends with a wealth of knowledge. Thanks Guy's.
Tim john--- |
that was a great buy
Ive paid much more than that for NOS Delco pumps many years ago keep that working pump as a spare in ziplok in trunk,they are easy to change on roadside if need be.
Thanks Cammer, will do !
Tj |
