Old 07-10-2021, 01:07 PM
chuckies76ta's Avatar
Default Screw in rims
Hi All: What's the consensus on screws in rims with slicks?
Like horsepower level, torque, weight of car, 60 times or ever the pressure you run them at.
Old 07-10-2021, 03:33 PM
AG's Avatar
AG AG is offline
I use Hoosier QTPs with tubes and screwed the tires to the rims, no problems or issues running 13 psi. 1.43 60' times with a 3558# car that runs 10.00.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 07-10-2021, 11:47 PM
Mike Davis's Avatar
Radial or bias ply?
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 07-10-2021, 11:55 PM
GTOGEORGE's Avatar
I have screws in my rims with tubes.
GTO George
Old 07-11-2021, 07:11 AM
Thanks guys. We mounted new MT Drag tires (28x10.5x15) yesterday to dry rims that were prepped for the bead and will see what happens. No screws yet. Car is only doing 1.49 60 ft with this converter. Car weights at least 3720. Ran a 10.30 at 132 mph first time out on new combo.
First time out we had the pressure at 18 psi with no issues, then tried 15 psi and no issues. This was before these new slicks.
Old 07-11-2021, 07:25 AM
Originally Posted by Mike Davis View Post
Radial or bias ply?
Were running M.T. E.T. Drag tires. They are Bias tires. Were using a 10" rim. Tire size is 28x10.5x15
They say not to run a tire on a rim that is more or less than 1" larger than tire. so were ok there.
Old 07-11-2021, 07:28 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I would think tubes = screws always. If they slip with tubes it could be ugly. Did ya mark the tire and rim to see if they're slipping? You're leaving pretty hard. I'd add screws.
Old 07-11-2021, 07:37 AM
I did mark the tires first time out and they moved maybe 3/4" and never moved after that. Track was prepped very well as they had some very fast cars that day. It dead hooked off the line every pass. We did 5 passes with no other issue except alternator belt flipping. (Pulley alignment). Thanks
RamblerRacer RamblerRacer is offline
At those tire pressures I’d try spraying the bead with hi tack gasket spray before going to screws.
We run our radials at about those pressures and use the hi tack with no issues.
The Following User Says Thank You to RamblerRacer For This Useful Post:
Old 07-11-2021, 07:39 AM
Thanks. Did the tire move any on first time out with the hi tack? We want to try the tires and rims dry to see what will happen. I did Somewhat of a knurl on the otter lip area of the rim so the tire bites to the rim better. If doesn't work will try the HI Tack method.
